SUPPORT OUR SPONSOR
February 2026
Old 10-29-2007, 09:57 AM
65cobra1's Avatar
Cobra Make, Engine: SPF #2450, Roush 342RE
Default Anti-seize
Hi Gang,
I've got about 3000 miles on my April-bought car and decided it was time to put anti-seize on the knockoff threads.
I pulled the first spinner and saw that there already was a dark, kinda greasy silver material in the threads. I'm assuming it was some sort of anti-seize.
My question is...I have a bottle of Cobra Valley's "Spinner Eaze." Even though there's already something on the threads, how often should that be renewed?
Thanks,
Ivan
Forget the health food...I need all the preservatives I can get !!!
Old 10-29-2007, 10:08 AM
Curt C.'s Avatar
Cobra Make, Engine: Classic Roadster; 351W
It should last for a good period of time. At least a year. It probably depends on how often the nut is cylcled too. Less cycles would equal longer time. Just my .02
Old 10-29-2007, 11:10 AM
Bob In Ct's Avatar
Cobra Make, Engine: SPF - 351W, 944 non-turbo
Spinners are like oil filters and soda bottle tops. If they are put on with "X" Ft-Lbs of torque it will take at least "3X" to get them off. The longer they're on, the harder it is to remove them. I remove and recoat at least once a year.
My $0.02 worth.
Bob
Old 10-29-2007, 11:14 AM
You should pull your wheels off at least once a year and use that time to inspect your brakes, hubs, suspension, etc. and then use a liberal application of anti-seize before putting the spinners back on. A spinner that has welded itself is an absolute nightmare. You don't need a dozen whacks with the lead hammer either, just a couple of taps and the sound will tell you it's tight. Then safety wire them.
Old 10-29-2007, 11:28 AM
Bx1 Bx1 is offline
Cobra Make, Engine: Superformance 351W to 393 Twisted Wedge Heads, Holley double pumper
Good, sound advice, thank you ... any recommendations regarding the type/brand of anti-seize lube?
Old 10-29-2007, 11:43 AM
I think I use "Spinner-Ease" (Finishline?), but I think any premium anti-seize is probably fine so long as you regularly apply it.
Old 10-29-2007, 01:49 PM
JBo JBo is offline
Cobra Make, Engine: Ex CSX3327, & AK7113 AutoKraft AC MK IV
Guys, would recommend the following as it has saved me from the problems I inherited. At least once a year off with the wheels, clean the hub threads as well as wheel threads wheel backs and pin drive holes with a solvent. Recoat all with a thin layer of anti seize ( I use NAPA...works fine) tighten knock ons with proper hameer and re safety wire two ears. Good to go! J Bo
Old 10-29-2007, 02:03 PM
65cobra1's Avatar
Thanks to all for the info...I'll put once-a-year anti-seize on the maintenance list.
"...and re safety wire two ears. Good to go! J Bo"
Just curious but did you mean you safety wire TWO ears?
Thanks again,
Ivan
Old 10-29-2007, 02:08 PM
I only safety wire one, as you can see below, but if I had a second wire going to one of the other two "ears" of the spinner, I think that is what he meant.
Old 10-29-2007, 02:23 PM
Default Speaking of Safety Wire...
If you want to go overboard on the safety wire, you can always safety wire your oil filter like I do. If you have ever in your life had an oil filter wiggle loose while driving, you will forever safety wire them.
Old 10-29-2007, 02:37 PM
Banned
Not Finishline, but sold through Cobra Valley. Awesome stuff and a little goes a long way. I also use it on spark plug threads.
http://performanceunlimited.com/cobr...innereaze.html
-Dean
Old 10-29-2007, 04:08 PM
-Dean
Yep, that's it and that's where I got it.
Old 10-30-2007, 06:33 AM
JBo JBo is offline
safety wire two ears and use a safety wire tool . Make the wire relatively tight. Safety wire is not designed to be a "tell" of a loose knock on, but to PREVENT a knock on from "walking" off
Old 10-30-2007, 07:22 AM
Originally Posted by JBo
... but to PREVENT a knock on from "walking" off
"Walking," as opposed to "wiggling."
HTML code is On
