SUPPORT OUR SPONSOR
Old 05-04-2008, 04:30 PM
Cobra Make, Engine: ERA 289 FIA #2027, 65' 289" PS wheels
Default refilling differentials and transmissions...pumps?
Does anyone know of a pump suitable for getting fluid into differentials and transmissions?
The fill hole on a Jaguar/Dana differential is pretty hard to get to. The trans is easier to get to, but hard to get the bottle up to run into the fill hole.
Last time I used a long plastic tube and held the oil bottle in the fender well.
Of course, the hose fell out of the diff, then the hose fell off the nipple of the gear oil bottle...total mess.
Am considering trying to use an old Holley electric fuel pump that leaks gasoline, but that shouldn't be an issue with gear oil. Was wondering if something like that Holley blue could move 90 weight or 75/140 gear lube?
Short of going to a shop, how do you refill diffs and trans?
thanks, Pete
ERA 289 #2027
Old 05-04-2008, 04:36 PM
Cobra Make, Engine: jbl
napa or oreillys usually have gear oil pump/suction tool that looks kinda like a grease gun.
Old 05-04-2008, 04:38 PM
Default Fluid Evacuator Plus
07201 Fluid Evacuator Plus
At the push of a button, this versatile unit changes from vacuum to pressure for evacuating or dispensing fluids. This functionality makes it ideal for draining tanks or reservoirs then pumping the used fluid back out for easy disposal. Multiple units work great, simply evacuate used fluids with one unit, and then quickly refill with new fluid from a second. For superior mobility, the 07201 utilizes a manual pump, so compressed air or electricity is not required. Accessories are included for draining engine oil or transmission fluid directly through the dipstick tubes.
Old 05-04-2008, 06:52 PM
xlr8or's Avatar
Valvoline and many other gear oils come in a dispenser with a pump. Napa has separate pump that will screw onto the common bottle sizes.
Old 05-04-2008, 08:47 PM
iwantacobra427's Avatar
Cobra Make, Engine: SOLD: ERA FIA #2114 with 331
Here's a pump you can use with a portable hand drill.
http://www.northerntool.com/webapp/w...DF&cm_ite=pump
Old 05-07-2008, 05:48 PM
Cobra Make, Engine: ERA 427SC FMS 351W
Default Marine Supplies have pumps
Most marine supply houses have hand pumps that screw into plastic oil bottles. They also come with a length of plastic hose with a metal screw fitting at the other end. These are designed to pump oil into outboard drive units. Simply cut the plastic hose at the metal fitting and use it to fill diffs and transmissions easily.
Old 05-07-2008, 05:57 PM
bigrob's Avatar
Cobra Make, Engine: BDR # 126/ K. Craft 306 CID/375 HP- 306 RWHP
Amsoil sells a hand pump for this specific type application! I have one and used it today for my tranny oil, and last year for my rear end oil on my Vett! I think it was about $20 or so. I will see if I can find it on their website! Go to the Amsoil.com website then click on Online store. In the search window at the right, put in "Hand pump" You will find it about 6 items down!! It's only $11 & change!! Works great. Just use a small hose clamp to hold the rubber hose on the pump snout, or oil will squeeze past a little and drip!! Good Luck!
Rob
" Listen to that music! "
'65 BDR #126
'84 Porsche 928S
'01 Corvette C5 coupe
'99 Ford Explorer Limited
Old 05-08-2008, 06:47 AM
Snakebit's Avatar
Club Cobra Member
Cobra Make, Engine: ERA 289 FIA #2100 Rio Red Wimbledon White Stripes 302 stroked to 331 Webers Richmond Road Race 5 speed
Take a regular oil can with a trigger pump handle and cut the tip off the flexible hose. Fill it with gear oil and pump away.
Snakebit
Old 05-08-2008, 09:28 AM
Cobra Make, Engine: Backdraft #520, 302 FORD racing Z50Z,t-56,391 posi
For the thinner oils,ie;atf,I use a garden sprayer with the nozzle cut off,clean and neat!
I never tried it with anything thicker,may be veerry sllooww!
Wayne Pontes & Mary Ann McAlinden
http://tangibletoys.com
Old 05-08-2008, 09:32 AM
Originally Posted by Tangible Toys View Post
...I use a garden sprayer with the nozzle cut off,clean and neat!
I've also heard that if you include a little MiracleGro in it that it will turn a Windsor in to an FE....
Old 05-08-2008, 06:49 PM
The oil can and garden sprayer sound to be on the right track.
Volume out of a squirt-oiler is pretty small...the Hudson sprayer type garden pump, especially a small one no more than a quart or two, may have some possibilities.
Something that can store the fluid you don't use till the next fluid change. Also cheap enough to have several, on for 90W for the Jaguar diff in the Cobra and one for synthetic 75/140 synthetic for my Jeep Grand Cherokee that seems to demand endless fluid changes. PITHA.
Now...MIRACLE GROW...great stuff...used it on the crankshaft...now I have a 347" stoker.
Really don't want an FE in the FIA car, but...could any of the "alchemists" out there that can suggest something to spray on the cast iron block that transmutes it to ALUMINUM? (Gold would be OK to).
Pete
ERA 289 #2027
Old 05-08-2008, 07:24 PM
bigrob's Avatar
Pete
Pete, The Amsoil pump IS what you want. It is very cheap- $11.95, comes with different size extensions for different depth bottles, two size screw tops for diff size bottle top threads, about 3' of hose, & little adapter to get in small fill holes! It screws on to the bottle and can stay that way till the next use. Do yourself a favor and check the website. I listed, in earlier post, how to find it, Kinda tricky!
You won't be disappointed.
Rob
'65 BDR #126
'84 Porsche 928S
Old 05-08-2008, 09:44 PM
Rick Parker's Avatar
http://www.amsoil.com/StoreFront/g2039.aspx
This type of pump is readily available at most quality auto parts stores such as NAPA. They work pretty well in a confined area, and if necessary can be tossed when done.
Rick
Old 05-09-2008, 09:08 AM
Cobra Make, Engine: Look-a-like cobra POS
Just ordered one, thanks!
B. Ewing
Old 05-09-2008, 09:17 AM
The one I got had a hose that attached to the bottom of the pump (inside the bottle of oil) that could be cut off to allow for different depth bottles instead of lengths of plastic tube as in the photo. Just be sure the pump screws onto the bottle or it could get a litttle messy?? BUT they work pretty well.
Rick
HTML code is On
