10-24-2008, 02:09 PM
NJ
Cobra Make, Engine: B & B
1/2 impact wrench Torque Recommendation
Hi,
I'm new to air tools. I have a 1/2 impact wrench with 300 pounds of torque--max. I am thinking I need another one with a higher rating for those tough lug nuts for example.
Any torque recommendations 500??? more???
10-24-2008, 02:20 PM
Banned
The majority of lug nuts should never exceed 100 ft lbs. (at least on aluminum rims like on a Corvette). I think on my C5 the specs are 85 or 95.
300 ft lbs is a tremendous amount of torque usually reserved for axle nuts, etc.
10-24-2008, 02:35 PM
NJ
Let me clarify. I am talking more about the torque needed to remove stubborn bolts/lug nuts, rusty bolts, etc. I am aware that I will probably never need that much torque to tighten bolts as you mentioned.
10-24-2008, 02:44 PM
GA.
I got on of those 1000 ft/lb composite guns from Matco. It is BY FAR the strongest 1/2 inch drive gun in the dealership.
10-24-2008, 02:58 PM
NJ
WOW Matco It must have cost a 1,000 bucks too!
10-24-2008, 04:12 PM
wa
Sorry, I don't use an impact wrench on anything.
If I take a vehicle in to have work done, I will tip them $20.00 or so not to use one.
10-24-2008, 07:02 PM
Having worked for the Tool division of Ingersoll-Rand in the past, I could be biased, but the new 2135TiMax is an awesome tool.
http://www.irtools.com/2135TiMAX/
I can probably get them for a very good price as well, maybe a little over $200. Shop around, they are all over the internet. I also have a 231 which is a very good tool for the money, probably around $100.
10-25-2008, 08:24 AM
GA.
Not quite. It was around $260. Although it is red & says Matco on it, I would say that it is produced by Ingersol Rand.
10-29-2008, 06:40 PM
Ingersal-Rand 244, if this won't knock it loose you need to be using a 3/4 drive gun. The composite guns are great if you like numb hands. (don't weigh enough)
1/2 drive has it's limits, but the 244 has yet to fail me.
10-29-2008, 09:44 PM
tx
Yes, get a 500# 1/2" inpact, you'll use it a lot. A 300# is considered pretty weak. Just because it's 500#'s, doesn't mean you should crank down your lug nuts to 500#'s, you should use a torque wrench to torque them down to 100#'s. But when removing them, it will take a whole lot more than 100#'s.
" It ain't no big deal"
10-30-2008, 05:50 AM
I've got a IR 2131. Alway's been happy with it.
They have since replaced it with the 2135TiMax
http://www.irtoolsales.com/ingersoll...impactool.html
02 Super Duty 7.3L
