SUPPORT OUR SPONSOR
January 2026
4 5 6 7 8 9 10
11 12 13 14 15 16 17
18 19 20 21 22 23 24
25 26 27 28 29 30 31
Old 05-03-2009, 12:50 PM
jerry w's Avatar
Cobra Make, Engine: Antique & Collectable 302, C-4,Ford 9 inch
Default Help! My cobra shuts itself off?
Looking for help and advice in tracking down this intermittent problem:
Driving along at highway speeds, anywhere from 30 to 45 mph. Not during acceleration but cruising. Engine shuts off.
Here are some clues:
- Rebuilt 1968 302 engine is always warm and up to temperature
- there is no sputtering or hesitation
- does not happen at idle
- does not happen when I accelerate
- does not happen every time
- running electronic distributor with ford parts
I am apt to believe I have an electrical problem, since the engine never stutters, hesitates or misfires. But if I am wrong someone tell me.
If anyone has input where I might start to track down this annoying problem I would appreciate all advice.
Jerry
Old 05-03-2009, 12:57 PM
767Jockey's Avatar
Fuel injected or carbed? What ignition are you running? I know it's Ford, but what is it?
Old 05-03-2009, 12:58 PM
FWB's Avatar
FWB FWB is offline
without more troubleshooting info its hard to make a call. but the first thing are the basics , fuel, spark, then output of the alternator, bad wire from ignition, msd? duraspark? loose coil wire?
Old 05-03-2009, 01:07 PM
jwd's Avatar
jwd jwd is offline
Does it start right back up or does it have to sit for a while?
Jim
Old 05-03-2009, 01:18 PM
jerry w's Avatar
Pull to the side of the road, put it in park, starts right up.
-running a carb
Jerry
Old 05-03-2009, 01:36 PM
jams's Avatar
Cobra Make, Engine: B & B
Could it be vapor Lock?
Just enough knowledge to build a cobra and be dangerous...
You can observe a lot from just watching.
Old 05-03-2009, 02:05 PM
Neutral safety switch.
Chas.
Old 05-03-2009, 02:08 PM
jwd's Avatar
jwd jwd is offline
-running a carb
Bad ignition switch or loose wire in the ignition system? I hate intermittent problems. If the damn thing would just stay broken, it would be an easy fix.
Jim
Old 05-03-2009, 02:10 PM
jwd's Avatar
jwd jwd is offline
That only effects the starting circuit. It does nothing once the engine is running.
Jim
Old 05-03-2009, 02:59 PM
Rick Parker's Avatar
Replace the Module inside the distributor, and the "BOX". Heat is causing open circuit.
Rick
Old 05-03-2009, 06:50 PM
I stand corrected JWD. I think Rick is on the right path. Is that the famous Ford "Thick film module"?
Chas.
Old 05-03-2009, 07:05 PM
Great Asp's Avatar
Cobra Make, Engine: SPO 2715
crack in the coil allowed the oil to get out.
Coil gets hot, engine quits,
Change coil
E
Old 05-03-2009, 07:09 PM
Dangerous Doug's Avatar
Cobra Make, Engine: ERA 289 FIA #2108
Yeah, check the coil. Get your DMM and test the voltage on the - and + poles. Jump in and drive around until it dies. Verify that it won't start right up, test the output on the coil again. I'll bet you on either the + or - poles you get the wrong voltage.
Make sure if you have an oil filled coil it is standing upright in it's mount, not laying on it's side.
DD
Dangerous Doug
"You're kidding, right?"
Old 05-03-2009, 07:27 PM
jwd's Avatar
jwd jwd is offline
Heat issues require a cooling off period that this situation doesn't appear to need. I'm still betting on a bad switch or a loose connection. Been there, done that. If it starts right back up, it's not a heat issue.
Jim
Old 05-03-2009, 07:57 PM
Sal Gerace's Avatar
Club Cobra Member
Jerry I am not a big guy and on occasion my knee has slightly rubbed the ignition switch and shut the car down. Sounds simple just something to consider.
Old 05-04-2009, 05:57 PM
jerry w's Avatar
Thank you all for replying. I am going to start eliminating all the possibilites mentioned one by one until I find the problem. Love this forum.
Jerry
Old 05-04-2009, 08:29 PM
Dwight's Avatar
Smile
check you fuel filter.
Dwight
Old 05-04-2009, 10:05 PM
Cobrabill's Avatar
Cobra Make, Engine: Superformance 427 Side-Oiler
Had a similar issue with a MSD Distributor.It turned out to be the magnet in the distributor was cracked thus interupting the "field".
The rest of the world can have their opinion about the United States just as soon as WE give it to them.
Old 05-05-2009, 06:25 AM
lovehamr's Avatar
Stolen Avitar
I think it's just rebelling because it has an automatic!
Steve
Old 05-05-2009, 03:17 PM
jerry w's Avatar
ahhh, lest ye forget the highest price ever paid for a cobra at BJ auction was...........equiped with an automatic!
Jerry
HTML code is On
