Old 05-21-2009, 12:42 AM
Cobra Make, Engine: keith craft 427, tko600, very shiney pile of parts
Default Fuel line size
Hi, I have a kc 427 and carby set up is 10mm hard line big enough from tank to mech. pump?
cheers glen
Old 05-21-2009, 03:17 AM
Default Yes it's just fine
tuska Glen that size is just fine for size of the motor unless you are going to spin the motor with a big carb at 7,800 rpms. Is the outlet on the gas tank the same size, and the pickup tube in the gas tank if you are not running a sump pickup system. Running bigger line is fine. You are only going to get as much flow as the smaller tube size in the system. Rick L. Ps Is the hose 10mm or 3/8" in size or where you going with #10 SS hose. There is a big differents.
Old 05-21-2009, 01:40 PM
thanks rick...just thort i'd check..in tank and fuel lines are 10mm internal dai so should do the job
Old 05-21-2009, 05:14 PM
Drag race it, monitor the fuel pressure and A:F ratio if possible. That will tell you if you have a big enough line/pump combination.
