SUPPORT OUR SPONSOR
Old 03-28-2010, 08:51 PM
Woodz428's Avatar
Cobra Make, Engine: Coupe,Blue w/white stripes SB; Roadster, Blue w/white stripes BB w/2-4s; SPF installer/Hot Rod-Custom Car builder
Originally Posted by Excaliber View Post
I find it hard to believe you even need the I terminal at all with todays modern electronic ignition systems. MSD doesn't use it, for instance.
Ernie is correct. Modern Ford solenoids only have the trigger terminal and not the I terminal( which is a bypass for starting and feeds the coil, not the ignition switch, although it is plumbed into the coil wire leading from the switch). The bypass is uneeded in modern electronic ignitions. It was used in the points set up to allow full voltage to the coil while the starter was cranking.
WDZ
HTML code is On
