SUPPORT OUR SPONSOR
January 2026
4 5 6 7 8 9 10
11 12 13 14 15 16 17
18 19 20 21 22 23 24
25 26 27 28 29 30 31
Old 06-08-2009, 09:39 AM
EarlsflyinCobra's Avatar
Ouch Ouch Hot Sand
Cobra Make, Engine: Street Beasts w/302 Twin Turbocharged....Under Construction!!
Send a message via AIM to EarlsflyinCobra
Default I'm so confused....Temp sending unit question??
I am in the process of installing and wiring the temp sending units. I have Autometer gauges and senders. I was reading the instructions (I know, WHY...LOL) and one place says to use teflon tape on the threads and in another place it says not to use tape on the threads for a good ground?? NOW, which is it, to tape or not to tape??
Safe Flyin, errrrr Drivin, Earl
Old 06-08-2009, 09:43 AM
FWB's Avatar
FWB FWB is offline
i used tape on mine.....
Old 06-08-2009, 09:56 AM
jwd's Avatar
jwd jwd is offline
It's okay to use tape with mechanical gauges, but electric ones need the sending unit to have a good ground. Use a little bit of teflon paste instead of tape.
Jim
Old 06-08-2009, 10:17 AM
Ouch Ouch Hot Sand
Oh, ok, I've been using mostly paste anyway, so I guess I'm good...who knew, I did something right by mistake
Old 06-08-2009, 10:38 AM
FWB's Avatar
FWB FWB is offline
i do my best work by mistake.....its when i start to think is when i get in trouble.
Old 06-08-2009, 01:13 PM
bobcowan's Avatar
All of my instruction specifically state to use a thread sealant. I use teflon paste.
Old 06-08-2009, 02:12 PM
Cobra Make, Engine: JCF supplied the body,frame,and some of the driveline-I completed it to be a very accurate 289 slabside
I never rely on threads for an electrical connection. It will probably work for a while but one day it won't.I solder or screw a terminal to the sending fitting and ground the other end. Carefully drill a tap hole for a 2-56 screw in the sending unit going just deep enough for about 3 threads so you don't break into the inside of the unit and then tap with a bottoming tap (no end taper). I would first try to solder on a wire. TIX solder has a very low melting point-wash off the flux when done.
Old 06-08-2009, 02:17 PM
If you are nervous about doing this I might add the wire for a reasonable fee. Mine has worked for 10 years.
HTML code is On
