SUPPORT OUR SPONSOR
November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 06-09-2009, 02:33 PM
EarlsflyinCobra's Avatar
Ouch Ouch Hot Sand
Cobra Make, Engine: Street Beasts w/302 Twin Turbocharged....Under Construction!!
Send a message via AIM to EarlsflyinCobra
Default Any Snow Water/Methanol Injection experts around here??
I am in the process of installing a Snow system. I have the tank that came with the system and also a 2.5 gallon, along with an upgrade solenoid. I was thinking about mounting the small tank near the nozzle in the engine bay, which will be difficult to get to, and then mounting the larger tank in an accessible location, having it feed the smaller tank. Is this feasible, or more trouble than its worth??
Safe Flyin, errrrr Drivin, Earl
Old 06-10-2009, 08:57 AM
Ouch Ouch Hot Sand
Okay, any NON Experts got an opinion on the 2 tank issue??
Old 06-10-2009, 11:31 AM
I don't see a problem with function, but I'd keep the whole setup as simple as possible.
Simon
Old 06-10-2009, 01:44 PM
Clois Harlan's Avatar
I know Dean Lampe has a swirl tank similar to what you have described that he uses on his GT 40 Dynatek set up (I know it is not for Turbo's but the principle is the same) and he has not had any problems with his set up. Good luck and I hope I haven't confused you.
Clois
"Let's roll"
"Be part of Something Good
Old 06-10-2009, 06:22 PM
Default 1 tank will work fine
Earlsflyincobra Earl one tank will work fine. This tank will last as long as a tank of gas. Distilled water works better than straight tap. It's only a misting unit. Make sure the flow is setup right. Just don't pump too much water through the motor. Also shut off the system and let the motor run for 20-30 seconds before turning off. This will get the water/meth mix out of the engine. The rest is test and adjust for timing and even running a cheaper gas. Rick L.
HTML code is On
