November 2025
| S |
1 |
| 2 |
5 |
8 |
| 9 |
12 |
15 |
| 16 |
19 |
22 |
| 23 |
26 |
29 |
| 30 |
06-28-2009, 04:04 PM
Ouch Ouch Hot Sand
FL
Cobra Make, Engine: Street Beasts w/302 Twin Turbocharged....Under Construction!!
How much did I add to the capacity??
OK, Here's a question for the math experts out there;
During construction of my engine I cut the back section out of the bottom of my oil pan and dropped it 1 1/2", so for the width of the pan, 9", and 12" of the length of the pan, I added volume.....so, my question is How Much??
So, I guess you take the measurements of the cube, 1 1/2" X 9" X 12" and do some fancy math and get the added volume, which is__________?
Safe Flyin, errrrr Drivin, Earl
Advertising
06-28-2009, 04:53 PM
nc
Cobra Make, Engine: A&C 408 stroker
There are 231 cubic inches in a gallon of liquid so your dimentions 9"x12"x1.5"
equals 162 cubic inches, 1 quart equals 57.75 ci, so 162 ci divided by 57.75 equals appx. 2.8 quarts (I think)
06-28-2009, 06:16 PM
Ouch Ouch Hot Sand
FL
Soooooooooo  ooooo  oooooo  ooooooooooooo oooo  , now I have a 7.8 qt. capacity oil pan plus two 3 qt. Accusumps, for a total of 13.8  qts. of oil. Sounds like a FUN oil change.
06-28-2009, 08:13 PM
NH
Do you purge the accusumps when you change the oil? I guess it only makes sense to.
07-01-2009, 03:46 AM
wa
Did you drop the oil pickup so that it's still at the bottom of the pan? If not, you did not gain anything.
In fact you may be in danger of oil starvation.
John Hall
07-01-2009, 06:39 AM
Ouch Ouch Hot Sand
FL
Good question, however I did not change the area of the pan where the oil pickup is located, just the rear part of the pan, so it shoud not effect the pickup.
07-07-2009, 12:50 PM
Ouch Ouch Hot Sand
FL
HTML code is On
