01-28-2009, 05:50 AM
Ne.
Group Buy-"MaxJax" 2 Post, 4 Arm, Home Garage Lift. $1,800 FREE SHIPPING !
ANOTHER SALE- (sorry, I can't find a way of changing the $1,789 price on the heading)?
Although the introductory price is over, I've talked with the company to have another sale. The price is $1,800 and......Free Shipping in the lower states !
HERE IS THE LINK-
http://www.garagejournal.com/forum/s...ad.php?t=35446
I have been using mine and I could not be happier. I have two stools, one with a telescoping seat and one that is a low profile that work great. If I'm lazy, I also lay down on my creeper. I just removed my engine and transmission, for my new side oiler & tranny, and it's done with ease. From major work to just maintenance and cleaning, I won't do without it.
I'll mention again that I do not work for the company. When I like products I like to share these with all of you through a "Group Buy". It's good for us and the company.
This car lift is for most home garages with low 8' ceilings. Mine is 9' so this one will be perfect. It's a two post four arms just like most professional auto mechanics use. I've been researching lift's and almost bought the "Kwik Lift" but after seeing this lift and how much more you can do, it was a no brainier.
This system is portable meaning, you can remove the bolts in the post base, tip it back on the rollers and store it all in a corner out of the way. I just leave mine anchored, as it's not in the way. I do disconnect the hose's and wheel the pump cart in a corner.
The arms more out 90 degrees, so even if you leave the posts in the ground, the arms will be out of the way, or. just remove the arm pins and store them. This is how I will use mine, no sense in removing the posts unless you won't be using it all the time.
When I built my Cobra, and I wish I had the lift then !
The car is so low, that even with my friends larger lift at his mechanics shop, I have to drive up on 2x4' on all wheels to get the arms under the frame rails.
I have to do the same at home and,....take my low profile jack to lift the front up a few inches, then the back few inches, then the back, to the front again ect.... until I get it high enough to lay on my back. It's quite a job and takes a lot of time. THEN, reverse the process. Hell, by the time all this happens, I'm pooed-out !
They even have a optional ATV/motorcycle adapters that easily converts one post into a full service motorcycle lift.
I will try to answer any questions you have, and I can post or email anyone more photo's. Also, I'm not, a salesman for this company, I just like spreading the word to all car guys if I like a product.
Here are some photo's.
Thank you,
Kevin Gilmore
Specifications
Lifting Capacity: 6,000 Lbs. / 2727 Kg.
Style: Portable Two Post Lift
Overall Height: 89" / 2261 mm.
Height of Column: 64" / 1626 mm.
Typical Width (Outside of Base Plate): 105" - 125" / 2667 mm. - 3175 mm.
Arm Reach (Min.): 24" / 610 mm.
Arm Reach (Max.): 44" / 610 mm.
Min. Pad Height: 3.5" / 89 mm.
Max. Lift Height (Pad only): 45" / 1143 mm.
Max. Lift Height (With 3" Adapter): 52" / 1321 mm.
Motor: 110-220 VAC / 50-60 Hz. 1Ph.
Time of full Rise: 30-Seconds
Individual Column Weight: 300 Lbs. / 136 Kg.
Shipping Weight: 880 Lbs. / 399 Kg.
Shipping Dimensions: 14" x 64" x 40" / 356 mm. x 1626 mm. x 1016 mm
FUNFER2
View Public Profile
Send a private message to FUNFER2
Send email to FUNFER2
Find all posts by FUNFER2
Sponsored Links
Reason: Update Listing
01-28-2009, 05:58 AM
KS
Cobra Make, Engine: jbl
how is shipping figured?
01-28-2009, 06:05 AM
Cobra Make, Engine: SPF#2189
Who makes them and where are they made.???
01-28-2009, 07:31 AM
Ne.
Shipping amount will determine on your location. If you want to email me with your address, I'll find out for you.
It is made by "Dannmar" and is called "MaxJax". Below is the company's site.
http://www.dannmar.com/products/two-...jax/index.html
Here is more information and a video,.... on how convenient, simple and how nice it is if you need to store the unit.
http://www.maxjaxusa.com/
01-28-2009, 08:03 AM
FL.
Cobra Make, Engine: n/a
Asymetrical arms make it a whole lot easier to rack a vehichle.......i2f
20mph is not fast, unless you are doing it in a 3/2, 1000sq. ft. house on 10 ft. waves!
01-28-2009, 08:40 AM
Ne.
Yes, and I plan on making or buying tire stops mounted on the floor, so I can be at the exact spot I need the arms, to the frame, for the cobra. Takes out the guessing. Know what I mean Vern.
01-28-2009, 09:42 AM
il
Cobra Make, Engine: #1459 w/460(sold)New(used),spf w/427s.o.(sold)
Guys, tell me if i am wrong but i was told that it is better to store a car w/weight of tires ????Why do so many use the 4 post lift if it is worse for suspension....I am in the process of lookin 4 a lift now.....I will use it as storage and to change oil etc......Any thoughts....Thanks
01-28-2009, 01:01 PM
Ne.
Hello Sparks, all you should do if you're storing a car is remove the wheels/tires, from the car. That is what puts extra weight on the suspension.
Email me at- cobrakev@galaxycable.net
if you have futher questions or want to order.
01-28-2009, 01:42 PM
il
Does anyone have a 4post who wishs they got a 2post or the other way ??
02-02-2009, 09:27 AM
Ne.
Garage lift now- FREE SHIPPING !
On all orders of the two post lift, it is now Free Shipping !
Group buy is over on Feb. 9th.
Click on link below to my original post.
Group Buy-2 Post, 4 Arm Home Garage Lift $1,789
02-02-2009, 11:35 AM
NY
Cobra Make, Engine: Backdraft, 302, Tremec 3550. #038
How thick does the concrete floor have to be that you are anchoring it to? Anyone know what the average thickness of a residential garage floor is?
Kids in the backseats cause accidents, accidents in the backseat causes kids ! Good reason to get a Cobra !!!
02-02-2009, 01:06 PM
Ne.
The concrete needs to be 4", which most home garages are, and have reinforcement like rebar or steel mesh wire.
02-02-2009, 04:11 PM
tx
Cobra Make, Engine: FFR , 5.0 Kenne Belle SuperCharged
You'll have to drill the floor for some type of bolt anchors to hold it down. Wonder what that would cost?? Did not see the bolts at first
FFR1182, 1968 GT500, 1968 GT350 Convertible, 72 Pantera
02-02-2009, 04:28 PM
Originally Posted by gt500bill
If you read the info, you dont bolt it down. It is portable with wheels
If the trees were not "bolted down", what do you think might happen?
02-02-2009, 04:33 PM
Ne.
lol !!!
You DO,..... have to bolt it down. You drill the holes, put in the included expansion sleeves and use the bolts to anchor the posts down. "Portable" means, you can take out the bolts and move the system in the corner of your garage or, take it to grandmas house, and use it there too !
02-02-2009, 07:03 PM
ca
Cobra Make, Engine: superformance/427 fe ford
hey kev, guess i'll be ordering mine before the 9th.
1952 MG TD - 53 HP 1970 SS454 Chevelle - 900hp 2007 spo2669 - 485hp 2001 Spclconst. softtail - 114HP 2006 Roadglide - 88HP
sold Roadglide.....bought 09 XR 1200 - 90 hp stock
i would rather live one day as a lion, than one thousand days as a lamb.
02-02-2009, 07:07 PM
Ne.
Hey bud, I did call them today about the cost of the motorcycle attachment and will get back to me tomorrow.
Email me again, I don't know what the @ell I did with it ?
02-03-2009, 09:36 AM
Cobra Make, Engine: West Coast Cobra w/ Centrifugally Blown Big Block, Pickles, Onions, on a Sesame Seed Bun.
Lift Utility
It appears as though a bridge could be constructed that connects between the parts that protrude out the top of the lift posts. Imagine a beam with two "soup cans" on the ends that slip over the top.
If that's true, they should sell that as an attachment for pulling engines, loading pickups, and what have you...
B
02-03-2009, 09:42 AM
Ne.
Very interesting idea.
I just emailed you back bud.
02-03-2009, 11:24 AM
Great idea (seriously). Now would you need another lift to move it into place? Or can you dead lift and press a couple hundred pounds of I-beam?
