Old 01-06-2010, 03:17 PM
Got the Bug's Avatar
Default Superformance Daytona Coupe w/LS3 Motor
I'm not on Facebook, but I found this link to the GM Performance Parts page with some info regarding 3 Superformance Daytona Coupes that are being built in the UK using the new LS3 E-Rod motor.
http://www.facebook.com/album.php?ai...8851883&ref=mf
http://www.superformanceuk.com/index.php
Old 01-06-2010, 03:30 PM
Doug, they say that necessity is the mother of invention. Well the UK and Aussie guys are way ahead of us in the mod motor/modern motor installs on these cars, especially in Cobras, because of their strict emissions requirements. I've read a couple threads here of LS7's in a Cobra.
Think about that for a moment. A stock LS7 in a Z06 is rated at 505HP. That car weighs around 3,100lbs without driver and in stock form on stock GY radials (and with enough practice) can click easy high 11's in the 1/4 mile. High 11's on street tires, and I know at least 3 owners that have gone mid 11's! Add drag radials and some have posted 10.9x times on a stock drivetrain.
Now take that same powerplant and subtract 500-600 pounds in a Cobra? Scary fast and super reliable. Doesn't look as period correct (only when you lift the hood), and may not sound the same, but it will still spank you (if you can get it to hook)!
-Dean
Old 01-06-2010, 03:40 PM
Blittleton's Avatar
CC Member / Sponsor
They look very nice in the engine compartment.
Squeaky wheel always gets the grease!!
www.gcperf.com
Old 01-06-2010, 03:46 PM
Dean,
I agree. The E-Rod is rated at 430hp. Purists might not agree, but if SPF offers an option to buy an LS3 compatible SPF Coupe they'll probably see some incremental car sales.
Old 01-06-2010, 04:26 PM
Xavier's Avatar
Cobra Make, Engine: Lonestar LS427, 408w, 48IDA Webers, TKO 600, 9" Currie 4-link 4.11 rear
KitCar Mag had a picture of F5's '33 Hot Rod with the blown Aluminator Ford racing engine in it. It looked great, and would look awesome in a Daytona. 700HP at the flywheel?
Old 01-06-2010, 05:48 PM
Bartruff1's Avatar
Cobra Make, Engine: Midstates/Shell Valley Street Cobra
Default fuk
I just put a Roush 427 in my 63 split window...
Old 01-06-2010, 05:55 PM
Cobra Make, Engine: jbl
here's an ad for a ls7...........and you can still call it a 427!!!!!!!!!
2007 Corvette Z06 7.0 LS7 Engine!
$$$$$$$$$$13,495Plus shipping
ONLY 470 ACTUAL MILES!!!!
Here is your chance to buy the most sought after GM engine package on the market today!
This 7.0L engine produces an amazing 505 HP @ 6,300 RPM and 470 ft-lb of torque @ 4,800 RPM!
2007 Chevrolet Corvette Z06 7.0L engine with only 470 ACTUAL miles! This is the lowest mile used package available! This sale will include the engine, engine accessories, air flow meter, flywheel, engine harness, engine computer, and pedal assembly! The dry sump oil canister and lines are also included.
The Vin of the Z06 this engine is from is: 1G1YY26E675108011
The LS7 features ground breaking technology such as:
Dry-sump oiling system
Unique cylinder block casting with large 104.8-mm bores
Pressed-in cylinder liners
Forged steel main bearing caps
Forged steel crankshaft
Titanium connecting rods
Cast aluminum flat-top pistons
11:1 compression
High-lift camshaft
Racing-derived CNC-ported aluminum cylinder heads
Titanium intake valves
Sodium-filled exhaust valves
Low-restriction air intake system
Hydro-formed exhaust headers with unique quad flow collector flanges
Engine Specs:
Displacement: 427.6 cu in
Bore & stroke: 4.125 X 4
Block material: cast aluminum
Cylinder head material: cast aluminum
Valvetrain: OHV, 2 valves per cylinder
Fuel delivery: SFI(sequential fuel injection)
Horsepower: 505 @ 6300
Torque: 470 @ 4800
Old 01-06-2010, 06:06 PM
Just to clarify, the point of the LS3 E-Rod would be to pass smog without a significant loss in performance. You could put that motor in an SPF Coupe in California and not have to deal with SB100.
Old 01-06-2010, 06:07 PM
I like that! Nice to see someone pi$$ off the Corvette owners...probably not that hard to do.
Old 01-06-2010, 07:22 PM
Blittleton's Avatar
CC Member / Sponsor
I thought 63 split windows came with a 327?
www.gcperf.com
Old 01-06-2010, 08:21 PM
Bartruff1's Avatar
I just figured it was what Old Shel would have done.
Old 01-06-2010, 09:14 PM
gt500bill's Avatar
Cobra Make, Engine: FFR , 5.0 Kenne Belle SuperCharged
No pics - didnt happen
FFR1182, 1968 GT500, 1968 GT350 Convertible, 72 Pantera
Old 01-06-2010, 09:59 PM
Ozgur_Tan's Avatar
Cobra Make, Engine: scratch built 289 eclectic mix of fia/ussrc/early comp
only exhaust headers does not look good
Old 01-06-2010, 11:27 PM
Ozgur_Tan's Avatar
what a coincidence i've received "BRE Coupe Newsletter" after send pictures of LS3 powered coupe
enjoy
ozgur
We enjoyed Datzilla at home in 2009 but there's no rest for the... well... restless. While Datzilla warmed our shop, our Superformance Daytona Coupe took a ride to Detroit where the foremost expert in Chevy engines (crew chief on the ALMS Pratt & Miller Corvette team) is switching out the existing Ford small block with a Chevy LS7. True to Peter Brock's nature (a man who "creates" and does not "follow"), he can tell you all the numerous reasons why this is a technically superior engine and all the issues it resolves (built in dry sump, physical size, etc, etc) that make it the perfect engine for the Coupe. Peter's xmas present was a call from Detroit. On the phone was SPC0073 running its new engine for Peter to hear!
We hope your 2009 was good to you as well.
Gayle and Peter Brock
BRE
Old 01-06-2010, 11:56 PM
PANAVIA's Avatar
Doug -- there are LS3 mounts available for the SPF DC. - now.
personally I would like to see the new 5.0L from the 2011 mustang GT in there. (411HP) and 27mpg with a 6 speed -- yeahhhh.
Old 01-07-2010, 03:13 AM
Cobra Make, Engine: Superformance MIII, Roush 427
If it wasn't for resale, I'd have dropped an LSX block under the hood of my superformance. I've owned one LS1 and one LS3, the motor make great power with a simple cam change and tune. It has a strong power band, reliable and best of all...CHEAP. I can't imagine how much more I'd have got spending $15K on an LSX verse my pretty Roush.
http://www.youtube.com/watch?v=mY2EYgsFXf8
That LS7 sounds good on the upper end, with a cam change that would be a fire breathing monster, sad part is it made more ponies then my Roush ;(
Old 01-07-2010, 03:55 AM
Original Shelby Owner
Cobra Make, Engine: AC427 MkIII of 2004 vintage
Nice to see the pics I shot on Monday pop up here on the Thursday! Small world. That's the new UK demo car which has just got its wheels on and is now mobile but still with a few items to sort out. I'm sure the headers issue will be sorted later. It was rapidly prepped for the NEC Autosport Show due to open on the 13th so we grabbed a few shots for the info sheet - just as well as the next day there was over 6 inches of snow on that driveway! (And it's still there)
I did get to 'drive' it but you imagine just how dam slow.....sounded rather wonderful though :-)
trev289
Old 01-07-2010, 05:51 AM
Cant figure out if you are BSing. Did you put a "Ford" based Roush 427 in your vette? The split windows have always been a favorite. When growing up my neighbor had two in the garage, who knows what they are worth now.
Old 01-07-2010, 08:54 AM
Cobra Make, Engine: era 427 side oiler
Question
wouldnt the rouch engine de-value your split window coupe?
Old 01-07-2010, 09:10 AM
Whoa Nellie?
I think I need to clean my computer screen. Did I read that right?
I thought I was living on the edge or at the "end of the world" within the Corvette community with a 540ci BBC and Tremec TKO600 5-speed in my '66 Corvette Convertible.
