Old 01-13-2010, 11:39 AM
Cobra Make, Engine: Backdraft, 351, 5speed
Default eldebrock 650 carb tuning
any pointers?
The idle stays fast (1100rpms) and only drops to 1,000 after warming up!
its a 351 w with a mild at best cam.
Old 01-13-2010, 11:53 AM
*13*'s Avatar
I assume you have backed the idle screw out & the carb won't close any further? Or is there another problem? What type of choke are you running? Is it adusted properly?
ERA FIA 2088
Old 01-13-2010, 12:12 PM
Sounds like the electric choke is to blame. Make sure the choke is fully open after a few minutes of warm up time.
Old 01-13-2010, 12:18 PM
Gaz64's Avatar
Yes, either the fast idle screw is still on the choke cam or you have a large vacuum leak.
Old 01-13-2010, 01:16 PM
Clois Harlan's Avatar
I once had an Edelbrock on my car and I had the same problem as you. As it turned out my shaft on my butterfly was warped and was causing it to idle fast all the time. Also, I had a problem with the Edelbrock washing down my cylinders after I shut the engine down. I have a Holley now!
"Let's roll"
"Be part of Something Good
