November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 06-29-2010, 11:37 AM
It's easy enough to tell....just pop off the intake and see what lifters are used. If it's a link bar lifter, then you can use a small base circle if the lift mandates it. If it uses a spider, then you can use the standard hydraulic roller lifters. If I'm not mistaken, if it's got a 1 piece rear main seal, it should be a roller block as well.
I wouldn't worry about the grind that's in it....just choose a new one based on the engine specs and what you want to do. If you need help, just let me know...I'm a Comp Cams dealer.
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
Rate This Thread:
