Old 09-05-2010, 04:04 PM
wrogers55's Avatar
Cobra Make, Engine: Backdraft #318, 418 CI, 532 RWHP, Mass Flow Injected, TKO600-Road Race, BMW M3 Suspension, Race Springs (Wouldn't do it again, rough on the street).
Default Offbeat SB head question
Can a head be pulled on one side leaving the intake in place and still bolted to the other side, then reinstalled and bolted up.
Can you get the gasket for the intake in place?
Stroked motor, 418, AFR 205 head.
Passenger side.
Unusual circumstance.
Is it possible?
Wayne Rogers in Hideaway, Texas
Old 09-05-2010, 05:20 PM
vettestr's Avatar
Cobra Make, Engine: Cobray-C3, The 60's body lines on todays chassis technology
Possible ... yes possible but not likely to get her sealed up again properly, pull the intake. Removal of intake makes removing 1 head no problem and allows you to reassemble without fear of vac, coolant or oil leaks.
Jeff Classic
Manufacturer of the Cobray-C3
www.cobrasnvettes.com
Old 09-05-2010, 05:27 PM
You can.....but dont
Old 09-09-2010, 12:24 AM
PANAVIA's Avatar
this is Like changing a tire whilst the car is driving.
Old 09-11-2010, 01:44 PM
I watched a 5.0 Mustang drag racer swap a single head gasket in the pits next to me and make the next round. It can definitely be done. Takes me more time to change plugs than the whole job took him. Pretty impressive.
Survival Motorsports
"I can do that....."
Engine Masters Challenge Entries
91 octane - single 4bbl - mufflers
2008 - 429 cid FE HR - 675HP
2007 - 429 cid FE MR - 659HP
2006 - 434 cid FE MR - 678HP
2005 - 505 cid FE MR - 752HP
Old 09-13-2010, 08:43 AM
Cobra Make, Engine: Factory Five GT-40 302 FI
Anything is possible but I keep asking myself....why would I want to?
Old 09-14-2010, 02:31 PM
Caprimaniac's Avatar
Cobra Make, Engine: Unfortunataly ; none
I did it, and it worked. Did use RTV on old inlet gasket which was stuck to the inlet manifold.
Old 09-17-2010, 09:36 AM
I think I might be about to learn a couple of new words.....
