Old 05-08-2011, 01:12 PM
Default Guess The HP & Torque Contest
How good are you? Guess the crank HP and Torque @ 6200 RPM and be the "expert" on this thread! I should have dyno results by the end of next week.
Bore & Stroke: 4.125" x 4.000" (427 CID)
Compression Ratio: 10.3:1
Cylinder Block: Dart 31345235 Aluminum, 9.500 Deck
Rotating Assembly: SCAT SuperLight
Heads: Edelbrock Victor Jr Heads 70CC
Bearings: Performance Clevite
Dampner: Innovators West Aluminum SFI
Oil Pump: Melling Hi-Vol
Pulleys: March, Aluminum Performance
Rockers: CompCam 1332-16 Pro-Magnum Roller
Lifters: CompCam 8931-16 Pro-Magnum Roller
Valves: Ferrea F6202 1.600 x 5.060 11/32 Exhaust, F6207 2.055 x 5.060 11/32 Intake
Camshaft: CompCam 35-426-8 (2200-6200 rpm)
Valve Springs: CompCam 928-16
Push Rods: CCA796016 7.650 5/16 Hi-Tech
Timing: ProGear Timing Set PG-4138
Distributor: MSD 8578
Pistons: Custom 70cc dish
Carburetion: 1 Willey's 4-barrel
Rate This Thread:
