Old 07-25-2011, 01:28 PM
Cobra Make, Engine: A&C,351W
Default 351 Windsor Operating Temp??
Is running back and forth between 190 and 230 about the standard range I should see on a hot day for the 351 Windsor? Just regular driving. Is 230 to high?
Thanks,
Aaron
Old 07-25-2011, 02:52 PM
bobcowan's Avatar
Should be fairly stable, depending on what thermostat you have. But a 40* swing is kind of a lot in my experiance. Air in the system, maybe?
.boB "Iron Man"
NASA Rocky Mountain TTU #42
www.RacingtheExocet.com
Old 07-25-2011, 02:58 PM
Cobra Make, Engine: Superformance #522
Typical is 185-195 F for mine.
Old 07-25-2011, 05:07 PM
Your fan should kick in and keep the temp at or below 200. Something isn't working like it should.
Jim
Old 07-25-2011, 07:01 PM
w-lewis's Avatar
Cobra Make, Engine: Unique, 351W
MY 351W runs anywhere from 180 to about 200. Without the fan at a stoplight during the summer, it might go to to 220 or so, but the fan will bring it right back to around 190-195.
Old 07-25-2011, 07:21 PM
*13*'s Avatar
I just installed a new 190 thermostat that wouldnt open til about 220-230. I replaced it with a new one that opens just above where it should. If it's going up that high, then dropping off, then you may have the same problem.
ERA FIA 2088
Old 07-25-2011, 07:28 PM
mreid's Avatar
Cobra Make, Engine: Kirkham 289 FIA #690, FRPP 427 Boss engine
If the higher temp is at idle or in stop and go, and the lower temp is at highway speeds, then you have the classic symptoms of an insufficient fan. This is the primary cause of engine temp swings like yours.
RCR GT40 SOLD to Fast 5
Kirkham #690 289 FIA
Rate This Thread:
