Like Tree4Likes
Old 08-01-2013, 02:58 AM
If you're not having issues with valve float now, you have no oiling issues. The oiling lines that Jim ran are to keep the solid lifters immersed in oil, as a solid lifter on the street needs ten times the attention.
Old 08-03-2013, 02:11 PM
Cobra Make, Engine: na
Originally Posted by bobcowan View Post
Oh, sorry. I meant the oiling mod. That looks like a fairly simple job I could do in the garage. I don't think I have any oiling problems now. But you don't really find those kinds of problems until something goes, Boom!
The lifter bushing, OTOH, would definately required a skilled machinist with specialized equipment. That is something I would not consider doing on my own.
As for the lifters themselves, I'm using Comp Cams hydraulic short travel lifters and beehive springs with a slightly higher rate. The engine easily runs to 6,500 rpm's.
Every year I consider solid lifters, just for the fun of it. But, so far, I haven't done it. I think at the last minute my smart brain over rides my crazy brain, and I stick with what works.
The Dart sportsman blocks are not cross drilled in the front like there iron eagle blocks. we at Kuntz and Co. have found it advantageous to oil the front pair of lifters at the same time as the back pair. Pushrod and rocker life is much better oiling from each end. This is handled in a different way on Iron eagle blocks. This actually helps the hydraulic lifters even more as they have to have a lot of oil supply and pressure to stay pumped up. As we all know with conventional oiling 1 and 5 cylinder pushrods are always the first to fail.
Old 08-03-2013, 08:23 PM
I was wondering when U would surface. Jim thanks for the clarification.
Mark
Old 08-05-2013, 09:56 PM
bobcowan's Avatar
That is really interesting, and I have never heard of this before. I am using a Dart sportsman block.
I have not had any problems with the lifters. But, I have had the the #1 rocker arm nut come loose more than once - despite a lot of torque and lock tite red. Next time I overhaul the engine (every other year at least) I will be doing this oiling mod.
.boB "Iron Man"
NASA Rocky Mountain TTU #42
www.RacingtheExocet.com
Old 06-17-2014, 05:12 AM
Hello Sir,
My name is Morten - I live in Norway (North Europe)
I googled Hillborn Smal Block Ford and I saw your thread here in this forum.
What a mighty cool engine you have got.
I have a 351W Dart block stroked to 427 and I have bought a Hillborn set up from Andrew Starr.
If you don't mind - I wonder what make / where did you get your ram tubes from ? And are you running some kind of top filters on those ?
With best regards
Morten
Old 06-17-2014, 10:13 AM
... and I did not want to break the bank
... We decided that most of my current short block components (463 SBF) were up for task
... Mark Davis Precision Race Engines
Nice motor PLDRIVE. If you don't mind me asking, how much did your makeover cost with you being able to keep your short block/components? If you would rather keep it private I understand, just curious. I see you had Mark Davis on the team, those guys know how to build "near" cup motor crates
_
Old 06-17-2014, 10:59 PM
Originally Posted by netrom19 View Post
Hello Sir,
With best regards
Morten
Morten i had Tim Engler (Engler Machine) make my ram tubes. He will give u all the guidance U will need. ITG custom filter. Do U want looks or performance?? IR manifolds are GREATLY affected by your choice of filter. Hope this helps.
Old 06-17-2014, 11:50 PM
_
Thank U very much.
AL427SBF the honest answer is i don't know. Most parts were purchased at different times and i never added the total up. I bought most of the components myself.
Mark is great guy, he and his brother Adam work very hard to provide a good product.
Old 06-24-2014, 04:01 PM
Hello Sir,
With best regards
Morten
Thank you Sir.
I want both look and performance if possible ?
What would a perfect performance filter look like and what would a cool looking filter look like ?
Sorry for my lack of knowledge
Regards
Morten
Old 06-24-2014, 08:43 PM
Morten U need a filter that can flow a ton of air. Your question is somewhat subjective, but It sounds like a large rectangular filter with a custom made polycarbonate top and bottom my be he ticket.
Take a look at the size of this sprint car filter (Racing Filters - Home).
Do not use these if u want performance (Hilborn Fuel Injectors) This bootie filter will takeaway a lot of horsepower.
ITG makes some excellent filters (but its going to cost U) They will flow a bunch (do not use K&N oil on their filter!!)
Some more info for U to consider. Tall Ram tubes = more low end TQ, Short Ram tubes = More upper end Horsepower
The shape of the Ram tube top is important ( can be worth up to 10% more power).
Hope this helps
Mark
Hope this helps
