November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Like Tree4Likes
  • 1 Post By moore_rb
  • 1 Post By blykins
  • 1 Post By Dimis
  • 1 Post By
Old 11-28-2016, 11:50 AM
Cobra Make, Engine: Cobra 302
Default Advise on Ford 302- 331/347
Hello
I wanted to know your opinion about the following topic:
I have a cobra with a 302 ford engine (1971), with edelbrock intake (dual plane), holly 650, and little else (stock pistons, stock camshafts, stock heads).
I wanted to increase the performance of the engine (supposedly gives 324 hp, I donīt dyno the engine, so it is a estimation that the seller told me), and wanted to know your opinions about what elements to install keeping in mind that in the future I will want stroke to 331 or 347.
I know I want to buy AFR heads (I know that if I were not to do stroker the best would be 165, but I wanted to know that you advise me in order to be able to serve both the 302 engine and the future 331/347 if it is possible.
Camshafts that are worth for both applications? (model or specs if it is possible?)
My current status is:
Differential 3.31
Gearbox tremec T5 (first of 2.95 and fifth of 0,73)
15 "wheels (215/60 15 and 235/60 15)
The use is 100% street (mountain ports and sports driving)
I would like it to go up to 7,000 rpm and have torque from below (say 1500 rpm - 6500 rpm, but could reach 7,000 rpm)
I would like to get in the 302 configuration up to 400 hp at least to the flywheel.
I would like to arrive at the 331/347 up to 500 hp at the flywheel.
Thank you so much for your opinions, are much appreciated
A greeting from Spain!
Rate This Thread:
