Like Tree5Likes
Old 03-16-2017, 12:00 PM
cycleguy55's Avatar
Default Hemi Heads for SBF
Specs:
  • Bolts on to any 289/302/351w and 351c engine blocks
  • Accepts any existing Windsor style intake manifold
  • Comes with 2.200”/1.650” Competition Series Stainless Steel valves
  • Sets up to 2.050” Installed Height (will accommodate big lift cams)
  • Has 62cc combustion chamber
  • Uses a Jesel 1.7 ratio shaft mounted rocker system
  • Has a Yates C3 exhaust bolt pattern (remote chance of existing C3 headers working)
  • Has accessory bolt holes for use with factory Ford accessories
  • Uses FelPro 1262R intake gaskets or similar
  • Uses FelPro 1433 header gaskets or similar
  • Comes with cast aluminum “Hemi style” valve covers
  • Uses Flatout valve cover gaskets
  • ​Has .700” thick deck for power adder applications
  • Has raised intake ports for more direct flow to the valve
  • Flow numbers are 392/intake and 275/exhaust as cast
  • Will require distributor extension
  • Comes with lifter valley cover
  • Uses standard Ύ” reach, gasket style spark plugs
  • Overall width of 9.5 deck engine is 27.5", 8.2 deck is 26"
Home
$4,995 per set
AndrewB, 1985 CCX and legenmetals like this.
Brian
Old 03-16-2017, 12:32 PM
lovehamr's Avatar
Stolen Avitar
That's cool!
Old 03-16-2017, 12:34 PM
*13*'s Avatar
wild!
ERA FIA 2088
Old 03-16-2017, 01:31 PM
cycleguy55's Avatar
It's worth noting the valve covers in the 1st photo are fabricated, the ones in the package are cast, like these:
Like that will be a factor in anyone's decision!
This would be impressive under the hood, especially with a set of Weber carbs or 8-stack EFI. Eye candy. Engine porn.
Or perhaps the side draft setup: V8 Kit, Ford 351W Cross Ram, 60mm Air Horn Kit - Part 200064
Now I just need to win the lottery!
Brian
Old 03-16-2017, 04:04 PM
Cobra Make, Engine: ERA 3012
Man, that is so cool! Think this would work under the hood of the slabside?
Old 03-16-2017, 05:49 PM
Hey u lot out there stop it u r bringing tears to my eyes
Old 03-16-2017, 06:02 PM
1795's Avatar
Pretty impressive looking. Has anyone tried them yet?
Old 03-16-2017, 06:50 PM
1985 CCX's Avatar
Wow, awesome however may be tight in a 289 car?
Old 03-17-2017, 10:09 AM
cycleguy55's Avatar
Ford Performance https://performanceparts.ford.com/do...Dimensions.pdf
  • 302 – 18 3/4"
  • 351W – 21"
  • 460 - 26"
Swap Sizing: Engine Dimensions & Tips for Popular Swaps - OnAllCylinders
Note: Includes exhaust manifolds
  • 351W - 24"
  • 429 / 460 (not Boss 429) - 27"
  • FE (not SOHC) - 27"
Dimensional difference 289/302 vs 351 - Vintage Mustang Forums
  • 289/302 - 24"
  • 351W - 25"
Width Range:
  • 289 / 302: 18.75 - 24"
  • 351W: 21 - 25"
  • 289 / 302 w/hemi heads: 26"
  • 351W w/hemi heads: 27.5"
Summary: 351W with hemi heads is wider than an FE or 385 series. Yeah, that would be a squeeze in a 289 car. Well, at least the spark plugs aren't buried deep under the heads!
I found this diagram on CC - very interesting:
Brian
Old 03-17-2017, 02:17 PM
joyridin''s Avatar
They look cool, but do they make any real power for that price?
Old 03-18-2017, 06:43 AM
Not a big fan of those rocker arms...
cdnus likes this.
Old 03-18-2017, 07:55 AM
byronpete21's Avatar
Cobra Make, Engine: ERA 289 FIA with a 347 cu in engine
Wow, those sure are pretty. 5000 dollars better bring some big horsepower gains.
Old 03-18-2017, 09:32 AM
The flow numbers look good, but you have to have enough displacement to use it. Ford's 427 FE wedge was able to hang with Chrysler's 426 Hemi back in the day, even though the Hemi had the advantage. If they would have increased the displacement to 500 CI under the same heads, the Hemi would have spanked the wedge.
That said I just do not see these heads doing much for a good 289, if at all. Even a 347 with good heads would gain very little, unless you reved it to the moon. I do think a Monster Windsor at 462 cid would make some serious power, if the bottom end is built to take some rpms.
I was surprised the exhaust valve was as small as it is, and the intake could have been bigger if they had wanted. Aren't these about the same size as a 4V Cleveland?
Old 03-18-2017, 10:47 AM
Cobra Make, Engine: FFR: 302 w/aluminum heads, Edlebrock injection. Street car trim, no scoop, side pipes or rollbar.
Send a message via AIM to Maricopa
Even at 460 that's a lot of money just to look cool.
"Cobra-Cobra-bo-bobra, banana-fanna-fo-fobra, fe-fi-mo-mobra...Cobra!"
Old 03-18-2017, 11:21 AM
I saw a set of these a few years ago at a Roadster show that were made for SBC. About the same money, but no matter how I phrased the question, nobody wanted to talk about hp gains and other technical questions like cooling efficiency, intake fitment, gaskets, etc....
I would hope for that money you could get huge hp gains from them. The flow measurements surely seem to be looking that way if you have enough cubes to take advantage of it.
Of course, guys spend a lot more money than this to make things look cool with no thought to hp gains, so why not this? Stacks come to mind...
Old 03-18-2017, 01:03 PM
505stang's Avatar
Cobra Make, Engine: B&B 351C
Not sure who makes these heads but Nick Arias has had a sbf hemi head out for quite some time, can also buy them for various hp, all depends on how deep your pocketbook is. Spoke to Nick several years ago at the PRI show about his heads and was very impressed at the heads. My racing partner used to race boats against Nick Sr years ago. They know how to make good HP!
Old 03-18-2017, 04:25 PM
Originally Posted by cycleguy55 View Post
Specs:
$4,995 per set
The valve sizes bugged me, so I looked up the Cleveland 4V heads. They are 2.19"/1.71" and the Chrysler Hemi Heads from the 1960's are 2.25"/1.94".
Also at first glance I realized these are not a true Hemi head. However when I looked more closely these are far from a Hemi head. I'm not sure they are deep enough to require a domed piston. They quoted a chamber CC that sounds like you could use a flat top piston.
Now that said, the Hemi head design has its problems. So maybe they solved a lot of problems with this design. However I'm not sure they will outperform a set of CHI heads.
Old 03-18-2017, 04:53 PM
Testing first small-block Ford Hemi | Moore Good Ink
Old 03-18-2017, 06:58 PM
These heads look almost identical to Kasse Boss 429 heads in the combustion chamber.
Probably didn't hurt that Greg Brown who makes them used to work for Jon Kasse
Old 03-18-2017, 07:28 PM
Default Heads
Poor FE, like a red headed step child. A nice wedge with the intake valve moved toward the center of the chamber would be nice. Nothing out there for us, we have to struggle on with milk truck design heads.
