Like Tree5Likes
Old 07-06-2017, 02:07 PM
ACHiPo's Avatar
Originally Posted by Texasdoc View Post
As best as I can tell from the picture, basically you are bypassing this solenoid, right? Since you have the battery terminal and the starter terminal on the same post, and nothing in the left post, it is not working as a solenoid.
Since the PowerMaster has a built in solenoid, you could remove this remote solenoid and do without. Or, if it is working, leave it alone.
Yep, the remote solenoid is acting as a junction for power, but I am using it as a relay for the all-important starter signal.
Old 07-06-2017, 05:18 PM
Gaz64's Avatar
That is not relay now.
I can't see why the solenoid coil terminals have four wires.
If you want to keep the solenoid, think about what is is really going on here.
To me the black wire on the LH post goes to the starter solenoid, so which wire is the start signal wire, and then what are the other two for?
This would be more appropriate:
http://www.novaresource.org/starter.htm
Old 07-06-2017, 05:43 PM
cycleguy55's Avatar
NovaResource - Remote Starter Solenoid Installation
Ford Solenoid:
A: Battery
B: Switched battery current when starting
S: Ignition switch 'start' position
I: 12V current for coil for starting (full voltage instead of reduced voltage normally supplied when ballast resistor is used)
Brian
Old 07-06-2017, 06:13 PM
Gaz64's Avatar
Originally Posted by cycleguy55 View Post
Ford Solenoid:
A: Battery
Thanks Brian,
I see that now.
That's if he is using a ballast resistor ignition, no mention of that yet.
Old 07-06-2017, 06:40 PM
ACHiPo's Avatar
No ballast resistor (that I'm aware of). The "S" is connected to the spade lug on the PowerMaster solenoid, the "A" is connected to the "Battery" terminal on the PowerMaster solenoid.
Old 07-06-2017, 10:43 PM
Gaz64's Avatar
Do you think you need this solenoid now you are using a starter with it's own solenoid?
You could remove this to tidy up the installation, unless you want it for authenticity?
What ignition system are you using?
Old 07-07-2017, 02:52 AM
ACHiPo's Avatar
I'm inclined to leave things as they are. There is a Superformance service bulletin I discovered Monday night that prescribes wiring the remote solenoid this way for PowerMaster starters (sure wish I'd had it Sat morning!). I need a relay to engage the PowerMaster solenoid, which is the only function the remote solenoid is playing.
Ignition is MSD.
