| S |
1 |
| 3 |
5 |
8 |
| 10 |
12 |
15 |
| 17 |
19 |
22 |
| 24 |
26 |
29 |
30 |
| 31 |
06-06-2018, 09:09 AM
TN
Cobra Make, Engine: SPF#1867 , KC427
Hammerhead Hemi Style SBF Heads
I came across these cylinder heads the other night and saw that the owner was affiliated with Jon Kaase in the past. Based on what was printed they look like some pretty nice results for a 427w. Did not know if anyone had used these heads in a build or had plans to do so. With a big 440+ci Windsor these look like they could potentially make some nice power on pump gas using hydraulic roller. I'm not as up to date with what is considered the "best" so there might be other options that are better suited for a street car running pump gas with a hydraulic roller setup but it was a product I had not come across in the past and though it was worth posting
Links
06-06-2018, 04:14 PM
$5K
Not going into a shock tower vehicle, I don't think.
06-06-2018, 06:08 PM
TN
Originally Posted by Dumpling
$5K
You have to pay to play. I would think its going to take a similar caliber cylinder head to maximize a streetable pump gas hydraulic roller setup in a big inch Windsor.
06-06-2018, 07:20 PM
QLD
They seem fairly good value for what they are.
Gary
06-07-2018, 09:35 AM
CA
Look at the torque curve in the Power and Performance News write up.
It starts nosing over in a hurry at 4500 rpm and manages to drop to 480 by 6400 rpm. This is not the kind of performance you would expect from a high flowing $5K set of custom heads. Even worse the torque decline shows no sign of letting up at 6400 but instead is headed south at an increasing clip and so is the HP.
A declining torque curve is the hall mark of poor volumetric efficiency. From a visual inspection of the photos you would not expect this. The dyno results tend to be the real thing however and they tell a very different story.
A 427 inch motor that only makes 600 HP is yesterday's news. A modest build using something like the old tunnel port heads with today's cams would easily crest 700 maybe 750 HP and still be a reasonably good driving street engine.
$5K is a lot of money for eye candy — and that is just the price of the heads. I am going to assume cam pricing would be a push. That still leaves custom intake, pistons, and exhaust that you have to step up for.
All in all there are better solutions available.
Ed
07-30-2018, 05:40 AM
I don't think the original Intent of the build was to be a crazy pump gas build.
07-31-2018, 08:35 AM
CA
and why would you build or use a head with a $5000 price point when you could build a more powerful engine using very much less expensive OEM components, standard aftermarket headers and a readily available wider selection of much lower cost intake manifolds ???
Ed
07-31-2018, 10:19 AM
AZ
"and why would you build or use a head with a $5000 price point when you could build a more powerful engine using very much less expensive OEM components, standard aftermarket headers and a readily available wider selection of much lower cost intake manifolds ???"
"lookee at what I've got"...BFD
Karlos
07-31-2018, 08:25 PM
CA
Missing pic, Karl??
Ed
08-03-2018, 12:18 PM
What OEM heads are you referring about?
CHI heads make a lot of power ..you're at least 4k into them.
08-03-2018, 02:44 PM
CA
You can get the new AFR Renagade heads for essentially $2K.
Click here => AFR Renagade
Ed
08-04-2018, 10:57 AM
Ca
Cobra Make, Engine: SAI FIA, 289HP (5-bolt), 48IDA Webers
I believe that the Shelby Engine Co. Has recently released a similar looking cylinder head? It looks like a baby BOSS 429.
08-07-2018, 07:21 PM
I never liked the inline heads unless they brodix
08-07-2018, 10:18 PM
I think I saw somewhere... facebook maybe? that they had a build where they were in the high 900's, scraping 1000 hp.
08-08-2018, 12:00 PM
SK
Ed
One of the customer testimonials for those heads quoted 715 HP. More HP for FAR less $$ sounds like a much better deal to me - unless someone places crazy value on eye candy.
Brian
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
