Like Tree19Likes
Old 11-14-2018, 10:52 AM
Default Oil "Use" Ford 427/535 Crate
Have about 20k miles on the motor, very minor oil seeps only, all 8 plugs light tan with timing and mixture tell tales all in the right place, no smoke, but she goes though oil? Maybe a qt every couple fuel tanks which sure seems like ALOT of oil...
I had oil burners in college and besides having to feed them oil the plugs were always black and gooey...Aside from having to add oil there are NO other tell tale signs of the thing either leaking oil, bad guide seals or leaky rings?
Made like 450 RWHP on the dyno...
A bit mystified?
Steve H
SPF 1764
Superformance 1764
Built 427W
Aiken SC USA
Old 11-14-2018, 11:33 AM
Dwight's Avatar
Smile
What kind of oil? Brand? Weight?
Old 11-14-2018, 02:35 PM
Default Oil
Just old pennzoil 10w40...
Superformance 1764
Built 427W
Aiken SC USA
Old 11-14-2018, 01:42 PM
Hotfingrs's Avatar
If the wrist pin is in the oil land, you're gonna burn oil. Built a couple big inch small block, burned like a quart every hundred miles. Never showed on the plugs. Last engine I built, 450 inch small block, I shortened the rod length 1/8 inch and moved the wrist pin down so it wasn't in the oil land. Never burned a drop of oil.
Jack
XSSIVE .....
Old 11-14-2018, 02:47 PM
Default So where does it go?
So the wrist pin is up in the rings on the piston?? Please elaborate.
Steve H
SPF 1764
Superformance 1764
Built 427W
Aiken SC USA
Danr55's Avatar
THe oil can only go two places. Out through the cylinders or out through a leak. Have you checked under the car for blow-by leaks? Do you have a light coating of oil and grime on the undercarraige anywhere?
Dan in Arizona
CCX3209
Old 11-14-2018, 04:02 PM
Having the wrist pin intersecting the oil rings has absolutely nothing to do with oil consumption. If it did, then every 347 on the road would be using oil....as well as many other longer stroke engines in other engine families. It's a wives' tale and it's one that gets my goat every time I read it.
Oil consumption can come from several places and it doesn't have to be piston ring issues. Valve seals can wear out, valve guides can wear, PCV valves can go bad, intake manifold gaskets can leak.
Some careful investigating will let you know where it's coming from. I'd start by pulling the carb off and seeing if there's oil laying in the plenum. If so, then it's probably something like a bad PCV valve. If you see oil on the intake valve stems, then it could be valve seals or guide wear.
Old 11-14-2018, 07:47 PM
Default It's not in the combustion chambers...
The intake under the carb is spotless...I'm using a walker pcv and a morosso oil catch, looking down the runners (super Vic) no oil, again plugs look great...it's got to be leaking somehow, but not a drip no signs of leaks...maybe a fine squirt somewhere that doesn't drip?
Need to do a real thorough chassis clean and crawl and chase this down.
Steve H
SPF 1764
Superformance 1764
Built 427W
Aiken SC USA
Old 11-15-2018, 02:37 AM
Steve H
SPF 1764
I don't believe a race car/street-strip car/hot rod should be anywhere near a PCV valve, but that's just my opinion.
Here's the thing....modern ignition systems are so efficient that they will burn the oil before it has a chance to get on the plugs or even show in the exhaust.
Do you have access to a bore scope? If so, I'd snake it down the plenum and look at the valves. If the valves are clean and the plenum is clean, then the next obvious thing would be piston ring issues. I've seen issues over time with Mahle coated pistons and the rings sticking...
Old 11-15-2018, 12:23 AM
Hotfingrs's Avatar
Sorry to get your goat, but these were on brand new engines, not just one but two. Every part in the engine was new. Burned a quart every 100 miles. Took the wrist pin out of the oil land, and not a drop of oil burned. BTW these were professionally built, not by me.
Jack
XSSIVE .....
Old 11-15-2018, 02:40 AM
Well, not trying to be a smart-alleck, but your sample size of 2 really doesn't represent the thousands and thousands of engines out there.
You would be shocked to see the amount of engines that not only leave my shop, but every other hipo engine builder's shop with the rings up in the wrist pin.
A 347 Ford is one of the worst situations with compression height...they are sitting at a 1.090" height, with the oil rings right up in there. I know of one particular guy with over 100k miles on his 347....no oil consumption.
The wrist pin intersection deal is just something that gets passed around the forums and it all stems back to a single faulty piston design from decades ago from Coast High Performance/Probe pistons.
Old 11-15-2018, 07:45 AM
PeteF's Avatar
Could be intake manifold air leak. Squirt some carb cleaner along the sides with engine at idle. If idle changes, you are sucking air and oil in from the lifter gallery. Also check torque on intake manifold bolts, they tend to loosen. This happened to me on a 351W with FelPro black rubber intake gaskets and cork front/rear. I was using a quart of oil every 500 miles with no smoke and no obvious leaks. I reinstalled intake with Cometic gaskets and RTV front/rear and oil consumption returned to nil.
Pete Munroe likes this.
Old 11-15-2018, 05:06 PM
RET_COP's Avatar
One more area an oil leak can occur, Wicking through the intake rocker studs. --Ask me how I know. Drove me nuts for a month. Once they were removed, dried and sealed my oily plugs and sheen in the intake runners was gone.
Lou
Old 11-15-2018, 05:13 PM
Thanks for all the ideas fellas, giving me some great things to check, Thanks
Superformance 1764
Built 427W
Aiken SC USA
Old 11-16-2018, 03:25 AM
The intake rocker arm stud is a biggie. It will put oil in your intake ports pretty easily.
Old 11-16-2018, 03:30 AM
RET_COP's Avatar
Brent what do you use for sealing. ARP thread sealant was terrible. I used ultra Grey which worked. Maybe I just didn’t clean the studs off good enough for the arp stuff to work but it took me twice to get them to seal
Lou
Old 11-16-2018, 09:01 AM
Default intake rocker studs
So if the intake rocker studs are removed, are you looking right into the intake ports???
Steve H
SPF1764
Superformance 1764
Built 427W
Aiken SC USA
Old 11-16-2018, 03:46 AM
I use Permatex thread sealant paste.
Old 11-16-2018, 11:08 AM
cycleguy55's Avatar
I've used the same - but my tube will last me a long time, while I suspect you're buying yours by the case.
Brian
Old 11-16-2018, 09:07 AM
It depends on the head and how deep the rocker arm stud holes have been drilled/tapped. On a lot of heads, yes, the hole goes into the intake port.
