Old 02-05-2004, 05:05 AM
Cobra Make, Engine: None Yet
Default AFR 185 Heads, Stud or Pedestal
I am planning to put AFR 185 heads on a 351W - 393 stroker. I am inclined to go with stud mounted rockers. Any good reasons to use pedestal instead?
Thanks,
auto10x
Bill
Old 02-05-2004, 05:26 AM
wilf leek's Avatar
Cobra Make, Engine: Crendon, windsor 408 stroker, tremec. Also GSX008
With the kind of rev limit I suspect you will observe in that stroker (6000?) I would have thought stud is fine. Are you going to the 7/16" dia studs if you have that option?
These seem to work fine for me, and I have some fairly stout valve springs.
HTH
Wilf
Old 02-05-2004, 05:48 AM
I used studs on mine, Bill. No problems.
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
Old 02-05-2004, 07:19 AM
Roscoe's Avatar
7/16" studs.
Roscoe
Roscoe
Old 02-05-2004, 08:42 AM
Thanks for the info.
auto10x
Bill
Rate This Thread:
