Old 02-14-2005, 09:16 PM
Cobra Make, Engine: Custom Built Classic Motor Carriage T 5 Z tranny still in the making ..
Default Carburated Intakes ?
Heres one I found any info on this one ?
Offenhauser Dual Port intake manifolds feature completely separate runner systems for the primaries and secondaries. At low-load, the primaries feed the fuel-air charge through the smaller bottom passages at near sonic speed, improving power and efficiency. When the secondaries open, their charge goes through the bigger, cooler upper passages. Then, in turn, it is rammed into the cylinders when it encounters the high-velocity mix from the primaries. The result is better fuel economy and a 15-30 percent power increase across the whole rpm range.
This model of intake for the 351w is supposed to not be in production any longer, and is not a common find. Just the regular base model of offenhauser intake for the 351w is well over $200.00 to purchase.
The offenhauser intakes are great power makers, and they are made of a better more pure aluminum and outlast most other brands of intake, as their water ports rott out alot faster. I sell many intakes and they get throughly inspected and have no no surprises like with many other sellers where there is a fix or repair job needed to use it. Also there is no clean up needed to bolt on, no stuck on greasy gaskets, no silicone gasket sealer to remove etc " the intake is 100% bolt on ready ".
What do you think ?
Need to save some bucks on my build but I dont want to throw what little I have either .
Thanks Tony
King Cobra
ALL IT TAKES IS TIME AND MONEY !!!
God Bless us All
