November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 06-04-2005, 08:09 PM
Cobra Make, Engine: factory five roadster with a stock 87 302
Default 302 ho valve adjustment
I have an 87 302 ho with hyd roller lifters.Do you tighten the stud bolt to a specific torque and measure clearance and adjust with longer or shorter push rods or adjust with the stud bolt.
Old 06-04-2005, 08:11 PM
The studs need to be torqued....
If your rockers are not contacting the pushrods correctly, then you'll need to get a adjustable length pushrod and check it....
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
Old 06-04-2005, 08:27 PM
Thats what I thought.Thanks for confirming it. I,m getting a pop out of the drivers side exhaust and thought I may have a valve not closing.
Old 06-05-2005, 12:21 AM
G.R.'s Avatar
Cobra Make, Engine: NAF 289 FIA, 347 stroker with Weber 48's, building a '48 Anglia gasser, driving a '55 Chevy resto-rod
Send a message via Yahoo to G.R.
Are you sure you don't have a leak on your header gasket or collector gasket? Is the "pop" under acceleration or deceleration?
I thought my "pop" was valve related but it turned out to be a leaking header gasket on the passenger side.
"Breathe in... Breathe out... then move on with life. Lifes too short to sweat the small stuff"
Old 06-05-2005, 05:23 AM
G.R. has some good points to check....also....is the car carbureted or fuel injected? You could have a rich/lean condition on that side....
Old 06-05-2005, 08:33 PM
Car has the factory fuel injection.It pops when I push the clutch in to shift.One pop like a firecracker in the exhaust.I thought I would do a compression check and replace the header gaskets on driver side.Hope it's a gasket.
