Old 07-17-2005, 04:33 PM
Default Main bolts vs. studs
Hi guys,
I'm wondering whether I should be using bolts or studs for my 351w mains. It's my understanding that the main advantage of studs is that they're better if you plan to open the motor up frequently. Do I have that right? I don't plan to be unbuttoning the bottom much, if ever. Also I see from ARP's specs that their studs are slightly higher in tensile strength than the bolts. Is there anything else I need to know?
Old 07-17-2005, 04:49 PM
I use studs everywhere I can.
Generally the tensile strength is a little higher....plus you lose the stress concentration of a bolt head.
In my opinion, it's also easier to use a stud versus a bolt....i.e. oil pan studs....
Old 07-18-2005, 06:45 AM
djseed's Avatar
30 Year Wait is Over
Cobra Make, Engine: SPF 1630 '70 429 SCJ / 501
I used studs on the bottom end for strength. I used bolts on the top end because on some installations there is not enough room in the engine bay to pull the heads if you use studs. This forces you to pull or lift the motor to remove a head.
David J. Seed
Q: What makes a good racer?
A: Size 14 shoe, size 2 hat.
Buddy Baker, NASCAR Hero
Old 07-20-2005, 12:09 PM
V-8's Avatar
V-8 V-8 is offline
Cobra Make, Engine: 67 Mustang with Eleanor body kit.408w+250hp NOS with alcohol
Send a message via MSN to V-8
I'm using studs with main girdle in my 408w
http://www.coasthigh.com/Main_Girdles/Main_Girdle.htm
_________________
ATAY AYDINER...
_________________
ELEANOR
[url]
http://www.clubcobra.com/photopost/s...at=500&thumb=1
http://www.motorspor.com/index.cfm?f...r&haber_id=250
http://fordboss.blogcu.com/1967-must...leanor/5605130
http://www.auto-drom.com/haber-trtuning.htm
http://www.motorspor.com/index.cfm?f...&haber_id=1897
Old 07-20-2005, 02:50 PM
Bolts stress the threads, on the bolt and in the block, when they are secured. Studs move the stress to the studs.
Studs are better, although not always necessary.
Also, ARP just intruduced a stud with a hew broached into the end so you can pull the stud to get the heads off, instead of pulling the engine.
One of those simple things that make a lot of sense.
