05-03-2006, 05:09 AM
MI
Oil Coolers on Street Cars
Rick's post on the thermostat thread brings up a question I've been pondering.
How many of you are running oil coolers on your street driven cars, and does it keep the temperature too low?
05-03-2006, 05:20 AM
I'm adding one this summer. Perma-Cool has a thermostat controlled bypass for their coolers that will bypass the cooler when the oil gets lower that 180 degrees (I think the temp was 180).
05-03-2006, 05:45 AM
az
Mocal has a sandwich adaptor with built in thermostat. I used one on my B&B and it worked great. It's an easy install if the filter clears the headers.
double ugly
05-30-2006, 08:57 PM
temp is too low
Guys,
On my car the oil-cooler face is covered with duct tape...for the last 4 years.
It takes forever to get temp above 140 or so...stuck in traffic, on a hot day I see 180-200 occasionally, but as soon as the car is moving it drops back to ~150.
Too low...have been looking at the MOCAL thermostat and pondering a nice clean, "low-flow-obstruction" install...as few bends as possible.
On the track, I still have had no reason to remove the tape from the cooler...haven't run in summer temps +90's at the track, but no problem yet...just the "around town" inablility to heat the oil to a temp that will evaporate the water out of the oil.
I have a 289 stroked to 347 with 10.7/1 comp...an AVAID pan with 10 quarts and aboutr 3/4 qt in the filter, cooler and lines.
Too cold isn't good...
Has anyone seen a remote filter head that incorporates a thermostat?...seems to be a better way than plumbing in a thermostat.
Pete
ERA 289 #2027
05-30-2006, 09:12 PM
OR
ERA FIA 2088
05-30-2006, 09:15 PM
OR
I purchased the Sandwich adapter with the thermostat. It doesn't cool until it reaches temp & I have no clearance issues with a special Wix oil filter. My Cooler , Mocal, is also a bit smaller than the unit supplied by ERA & the ones seen on most of the early comp cars.
ERA FIA 2088
06-07-2006, 09:07 AM
Cobra Make, Engine: Unique 289 FIA,302 Crate,Holley 600cfm
Alternative?
Saw this and thought it would be a great alternative.
I've been happy that I added an oil cooler but then this is Arizona.
http://www.lbcarco.com/cgi-bin/gen5?...l&o=&a=&t=_top
Best
Scott
HANDLE WITH EXTREME CARE: This product contains minute electrically charged particles moving at velocities in excess of five hundred million miles per hour
06-07-2006, 09:37 AM
I use a manually operated by-pass valve. It is integrated into the remote filter mount.
It allows me to proportionally flow as much oil as I want through the cooler. It has -12AN ports for low flow restrictions.
I run -12AN from the engine to the valve/filter. Then -10AN to my oil cooler.
I think my oil temp runs on the cold side most of the time, even wit the oil cooler closed. But when I drive with higher engine revs, say maintained at 3500 and up, the oil temp gets dangerously hot and I need the cooler. At a track event for example.
More info on these valves are at: www.beaumontmetalworks.com
06-07-2006, 10:59 AM
Beam Me Up Scottie
MA
With the remote oil cooler, it takes a long time for the oil temp to reach operating temp.
During all conditions, the water and oil temps are within 5 ºF of each other.
Warren
06-07-2006, 11:43 AM
OR
Those are both great ideas!
ERA FIA 2088
06-07-2006, 01:54 PM
NC
Cobra Make, Engine: ERA 427SC w/427so, ERA GT #2002
I simply tape over the cooler. As outside temperatures get warmer or I race the car, I peel off the tape. It's simple, light and doesn't break or leak . . . did I say cheap.
Tom
"If you can make black marks on a straight from the time you turn out of a corner until the braking point of the next turn, then you have enough HORSEPOWER." Mark Donohue
06-07-2006, 02:38 PM
Cobra Make, Engine: Superformance #1048, 392w
Yeah whats wrong with duct tape?
I did a cad model of a nice form fitting piece of stainless which kind of locked by screws on either side... didn't want to spend $$$ on getting it fabbed up.
In Cali, I haven't seen it run so low I was concerned... I'd be more concerned if that oil never got hot, which it seems to do. What concerned me is my oil pressure, but I have resolved it to my satisfaction through a HV adjustable pressure melling pump.
06-08-2006, 10:56 AM
*13*,
No. 13 is a good looking car!!
06-25-2006, 08:48 AM
Cobra Make, Engine: SPF 974
Bypassed mine on my street driven car 4 yrs ago. It's in there...looks cool but the AN fittings join up under the cowl via a double male connect as one loop. The only difference I noticed were 12 feet less oil line and 3-5psi rise on oil pressure.
07-04-2006, 01:10 AM
IL
Cobra Make, Engine: B&B w/FRPP 347ci 450HP Crate
Which special WIX filter are you running? What are the cons of running the shorter filters?
07-04-2006, 05:38 AM
During cooler weather I have a piece of plexiglas in front of the cooler. You can't even see it. I also use 5W-30 (rather than 20W-50) since it provides plenty of pressure and flows more easily through all the extra tubing required by the cooler.
07-04-2006, 06:05 AM
AL
Oil / water temperature
Last winter I install a Canton 7qt oil pan and a oil temperature gauge. I have a 5.0 EFI set up. My oil temperature is 180 F and the water is 195 F. I thought the oil temperature should be 20 degrees higher than the water???
Dwight
07-04-2006, 07:52 AM
NJ
I run a Canton Road Race oil pan and a Mocal sandwich type thermostat with -10 oil lines on my 351W. Fortunately, I have enough room to also use the standard oil filter rather than the FL-300 shorty. When the oil temp is below that required to open the thermostat I get 65 lbs. at idle using 10-40. I can tell when the thermostat opens because the pressure then drops to 58 lbs. at idle. I have run this setup for four years now with no concerns. The setup is simple and effective.
07-04-2006, 08:48 AM
Cobra Make, Engine: Compomotive. 351w, close ratio four speed, live axle, 4wdb.
Perhaps you guys could educate me a little. What would the acceptable oil temperature during normal driving? As the oil heats up, where would the upper limits of temperature be and when should I be concerned that it is getting hot to the point of damage?
My 396 stroker runs water temp right at 185 degrees and my oil temperature stays about 200 degrees. When I run it hard, the oil temp will creep up to 225 or so. Occasionally I have seen 240. I have the canton, but don't run a cooler at this point. Should I re-connect the cooler ? The temps here in Sac. run 100 degrees + in summer.
Any advice would be appreciated.
Tinman
07-04-2006, 09:43 AM
Hi Mark!
You are fine. I get those temps all the time too, maybe even a little hotter. Oil should be hotter than water. Oil under 212 is bad. Basic rule is use really good oil. My builder prefers the vr1 valvoline. Has extra stuff in it to lube valvetrain parts too.
As long as the oil is good your engine is good too.
JB
