February 2026
Old 06-05-2006, 01:16 PM
Mark Brye's Avatar
Cobra Make, Engine: BDR354/FMS392
Default Adding AFR185's to FMS392
I have read a bunch of posts about adding AFR 185 Heads to the 392 and how they make so much more power. I read the MM&FF article and a couple others. I emailed Keith Kraft and asked them about adding these heads and they said there should be no piston to valve clearance issues. But I read a post on here that someone had bent a push rod.
Is there enough room for these heads? If I have to flycut the pistons then I will just leave the heads that are on there now.
Thanks
Rate This Thread:
