Old 10-19-2006, 11:04 AM
Wayne Maybury's Avatar
Canadian Gashole
Cobra Make, Engine: Johnex 427 S/C, 351W, 472 HP, 444 lbs. torque
I am not 100% sure but I don't think that Rotella T is a synthetic oil. However, Rotella T is one of the better oils to use with a flat tappet cam.
The additive that has been greatly reduced in oil is ZDDP. The reduction was at the request of the EPA, I believe. I contacted STP who told me that their "STP Oil Treatment" contains a high level of ZDDP so adding a can of STP with each oil change should increase the level of ZDDP in your oil.
If you like a really thump, thump, thump, sounding idle, then stick with the flat tappet cam. I find that many engines equipped with roller cams have a much more civilized sounding idle. I assume it has to do with the overlap and the profile of the lobes.
Wayne
Don't get caught dead, sitting on your seat belt.
Old 10-19-2006, 11:28 AM
rdorman's Avatar
Renegade Nuns on Wheels
I use full synthetic 5W-40 Rotella T in my flat tappet car.
Back to the original question. A roller will generally make more power all else being equal. But it is all in the cam design for the application. Higher opening and closing rates are possible (with cooresponding higher loads on valve train components) with rollers so if we where to compare a flat tappet at the highest practical ramps with a roller again with the highest possible rate of open and close, the roller would make as much or more power in the same power band as the flat tappet with less duration. Higher cost is a factor but overall the roller is a superior design. Don't pick the cam yourself. After your head work is done and you have that data, talk to the experts. And then pick a cam. Be sure your geometry is right on the money. Circle Track ran a good article a while back (this year) on how to check and correct this. While you are at it, the new beehive springs are showing a LOT of promise in the area of valve train control.
OhioCobraClub.com
LondonCobraShow.com
Old 10-20-2006, 02:25 AM
69 Mach I's Avatar
Cobra Make, Engine: No cobra YET. Making do for now with a 69 Mach I
These are the flow numbers after porting:
Intake/Exhaust .100" 79/61
Intake/Exhaust .200" 145/121
Intake/Exhaust .300" 198/168
Intake/Exhaust .400" 241/178
Intake/Exhaust .500" 279/196
Intake/Exhaust .600" 284/205
I have 3.70s in the back and a 2800-3000 stall. I am thinking that this would be a good cam to go with it:
Comp Cams part number 35-426-8, grind no. XR288RF-HR (Hydraulic roller)
Adv Dur:
Intake: 288
Exh: 294
Dur at .050
Intake: 236
Exh: 240
valve lift with 1.6 rocker
Intake: 555
Exh: 576
Do you guys concur with this selection?
I can only please one person a day but today is not your day. And tomorrow isn't looking too good either.
