Old 12-06-2006, 11:50 AM
Cobra Make, Engine: LA Exotic
Default Identifing 351W engines and heads
Can anyone direct me to a site to determine exactly what year engine I have. Bought a used LAE...previous owner wasnt sure of what engine was used.
Old 12-06-2006, 12:19 PM
There's a cast number on the block and heads that should start with a letter....can you find those?
i.e. C7ME-A or C5AE-A, etc....
If I remember correctly, it's under the oil filter on a Windsor block.
Old 12-06-2006, 12:58 PM
1bad66's Avatar
Cobra Make, Engine: Streetbeast, 351W
It is over were the starter mounts. there is a little smooth flat area right above the starter.
Old 12-06-2006, 01:24 PM
Zoom This's Avatar
If your 351W engine number starts with a C followed by a number e.g., C9xxxxx, it's a 1969 block, C8xxxx is a 1968 block etc. If the ID number starts with a D4, it's a 1974 block. C=60's blocks. D=70's blocks, etc. Number after the letter indicates the exact year in that decade.
Old 12-06-2006, 03:08 PM
Poolw's Avatar
Cobra Make, Engine: SPF, KC 427
Hey, Mike, I understood it was a 74 block.
To my Cobra: - - when I'm with you - Oboy!
Old 12-07-2006, 07:27 AM
Thanks Warren...thought that was what you said...how bout the heads guys.
Warren did you get the dyno results...I sent it on Monday and resent this morning.
Old 12-08-2006, 04:49 AM
Here are some numbers.
CASTING NUMBERS
1969 351W engine block -- both 2 barrel and 4 barrel engines -- C8TE-6015-A
1970 351W engine block -- both 2 barrel and 4 barrel engines -- C90E-6015-A or C90E-6015-B or D
1970 351C engine block -- Before 10/15/70 --D0AE-6015-A, C, E, G, J
1970 351C engine block -- After 10/15/70 --D0AE-6015L
1969 351 V-8 Windsor 2 barrel heads -- C90E-6090-A, B, D, F, or J
1969 351 V-8 Windsor 4 barrel heads -- C90E-6090-A, B, D, F, or J
1970 351 V-8 Windsor 2 and 4 barrel heads -- D00E-6090-C or D0AE-6090-J
1970 351 V-8 Cleveland 2 barrel heads -- D0AE-6090-E or D0AE-6090-J
1970 351 V-8 Cleveland 4 barrel heads -- D0AE-G, M, N, or R
