Old 01-18-2007, 12:04 PM
Send a message via ICQ to butch
Default 5.0 accery drive
I am new to 5.0 building.I would like to know witch year and model has the most compact accersy drive,both in width and depth hight dosent mater.I prefer to use stock ford parts.
Old 01-18-2007, 02:24 PM
woody2's Avatar
Cobra Make, Engine: B&B 302ci
Whats an accery drive?
Old 01-18-2007, 04:12 PM
accessery. You know water pump,alternator,power steering,air conditioning.Are you a teacher?
Old 01-19-2007, 12:28 PM
Cobra Make, Engine: StreetBeast 66 replica 302 350HP
it depends on what you are going to use, i.e. under-drive pulleys, single wire alternator, electric fan and so-forth, the year of the engine shouldn't make much difference, you can use the timing belt system are the v-belt system, there are a lot of variables
PapaJohn
Old 01-19-2007, 08:29 PM
ByronRACE's Avatar
Cobra Make, Engine: West Coast Cobra w/ Centrifugally Blown Big Block, Pickles, Onions, on a Sesame Seed Bun.
Default Most compact accessory drive...
The most compact accessory drive would be to run a crank pulley and a single accessory like a water pump OR an alternator or no accessory drive at all...I guess the absence of an accessory drive is the smallest of all, since it doesn't exist.
What do I win?
To get a serious answer, what accessories and belt system are you interested in running?
Byron
Old 01-20-2007, 08:21 AM
HighPlainsDrifter's Avatar
Cobra Make, Engine: F5 Roadster
Default compact
Hi,
The smallest system is no belts at all in the engine bay;
use an electric water pump.
place the alternator on a pulley next to the front of the driveshaft.
Now there is nothing in the engine bay.
Perry.
