Old 02-01-2007, 12:29 PM
Default guideplates needed for shaft mount rockers?
I want to install a set of shaft mounted rocker arms on Edelbrock Performer RPM heads.
The heads have guideplates installed from the factory. The rockers are positioned on the shafts with bronze washers, however there is still some sideplay left:
Can I remove the guideplates and use non-hardened pushrods or should I keep the guideplates?
Thanks,
Simon
Old 02-01-2007, 01:44 PM
ERA-FIA's Avatar
Cobra Make, Engine: ERA fia, 400 c.i. W
I'm running shaft mounted rockers and no guide plates. I don't believe they are necessary.
Old 02-01-2007, 03:20 PM
You do not use guideplates with shaft mounted rockers, use a good hardened pushrod
FordStrokers
1-877-SBF-KITS
Old 02-02-2007, 10:32 AM
Alright, no guideplates. But why are hardened pushrods needed if they don't come in contact with anything (except for the tips) ?
Old 02-02-2007, 12:08 PM
Manowar's Avatar
It's a more durable piece if you should upgrade cam and stiffer springs. It's not a much greater expense than standard, especially since you've upgraded to a shaft system. It's good insurance, especially in the 5/16 size.
Rate This Thread:
