10-18-2007, 06:03 AM
Fl
Cobra Make, Engine: BDR # 165 392 Ford Crate 430HP
Best jet size, etc ?? 650 Holley 302 Ford crate
Would really like to hear from someone who has the same engine..I recently bought a cobra with 302 Ford Racing 340HP came with 650 Holley double pumper # 4777-7 stamped on horn with mechanical secondary. Car doesn't seem to run right almost 99% sure it is carb related, stumbles etc... fuel pressure is 4 lbs has a electric Carter fuel pump Part #06K20A & P61296 on sticker looks to have plenty of flow, plugs look to be proper color.
What size jets would you run in primary-secondary and what other mods to carb would you recommend such as power valve-whistles in bowls.. best rebuild kit Barry Grant?? Its been 20 years since I last worked on a Holley which was mounted on a supercharged 1985 Mustang GT.. I am a little rusty..
I am going to remove it and check it over so it would be great if I knew the best set up so I can get proper jets, etc.. Car is strictly used on street not a dedicated racer..
Like a kid in the candy store I just can't get enough
Current rides GT500 & Backdraft
10-18-2007, 06:23 AM
Ill
I've found as a first step is to find out whats in the carb as to jets and power valves and then check to see what Holley put in it when they made it
As a general note on most street engines the proper drivable jets will fall in a range of numericlly being about egual to the carb cfm
ie 650 carb---aprox #65 jets, 700-750 carb---70-72 jets, 800 carb 78-80 jets
Make sure your power valve isn't blown and is rated a couple numbers below your engines vacume
The carbs haven't changed since you worked on them, still don't look down the carb while the engine is cranking!!!!
Jerry
10-18-2007, 07:04 AM
Fl
The guy who owned it before said it was running perfect, could be the change in elevation, CT then Florida. Said he gained 35HP with 650 over a 600 on dyno.
10-18-2007, 07:11 AM
Ill
Most carb problems I see were caused by a dyno operation---max power does not equal drivability
10-18-2007, 07:36 AM
VA
I have a carbed 302. I am putting out about 400hp. I have a 650 DP same as yours. When I upgraded to a single plane manifold, I had to upgrade to 72s in the front and 78s in the back. My car runs awsome!!!! I don't remember what the jetting was before, but it was MUCH leaner. A single plane manifold requires measurably richer jetting than a dual plane. Plus, you can get away with a smaller carb on a single plane than a dual plane since all 4 venturies can feed each cylinder vs only 2 venturies on a dual plane. But, as I indicated, the jetting must be richer.
I also have the K&N Stubstack on the carb which adds andother 28 CFM and smooths the airflow. I didn't notice much improvement at high rpm when I added it, but throttle response and mid range were noticably improved.
________
________
10-18-2007, 09:09 AM
Ill
650 + 28 = 678 round up to 700 sort of fits my profile, huh?
The stub stack will significantly flow more at the lower carb openings, causing the carb boosters and venturis to act like considerable bigger carb
You can put a divider in the single plane manifold plenum area that will pick up the lower ranges response
Jerry
10-18-2007, 10:29 AM
Beam Me Up Scottie
MA
If the plugs look OK, and the only thing that is wrong is the car stumbles, I would look at the squirter size, or a different squirter cam. But it all depends if the stumble is a lean condition or an over rich condition.
Get the RPM's above 3000 RPM in any gear and mash the gas pedal. If there is NO stumble, look at the squirter and squirter cam.
Warren
10-18-2007, 10:38 AM
Ne.
Do you have a local business that has a chassis dyno ?
That is the BEST,...way of tuning your fuel curve timing ect.. rather than in your garage or on the street. It's well worth even traveling to find one.
Kevin
10-18-2007, 10:42 AM
Ill
I agree with that somewhat---when the jet size is set for max power, then the drivability issues need to be dealt with within that wide open mixture ratio
It usually comes down to float hights, accelerator pump cams and squirters, along with getting the car to idle without so much throttle tip in that the idle circuits are out of the picture
I also use a much lower rpm to chech acceration and driveability 1500 rpm is good place to start and do it in 2 or 3 or else you will be at such a high road speed that it gets dangerous
Jerry
10-18-2007, 10:45 AM
Ill
I meant 442 post not funfer2
There is no way to successfully duplicate driving on a chassis dyno--
Flame on
Jerry
10-18-2007, 10:46 AM
Beam Me Up Scottie
MA
Based on Holley's carb numerical listing
http://www.holley.com/TechService/Library.asp
that carb originally had 67 primary and 73 secondary jets with a 65 power valve.
Warren
10-18-2007, 10:52 AM
Ne.
The great thing with a chassis dyno (if the operator know's what he's doing)
you can make a full run, read the numbers and adjust the mixture at high rpm's then do a idle adjustment through the whole rpm range and you're set. It's well worth the money.
Kevin
10-18-2007, 10:55 AM
Beam Me Up Scottie
MA
Jerry
I agree with you about seat of pants driving conditions, but a dyno will tell you if the jets are too lean or too rich. It will also tell you if a low speed stumble is because of a too lean or too rich condition. Then after the jets are OK (and the power valve), then you can play with squirter's, etc.
I find that many people make 2 or more changes to a carb at the same time. Bad decision. Only make ONE adjustment and then see if problem is better or worse.
Warren
10-18-2007, 11:03 AM
Ne.
We had a guy come to the dyno that raced in the Pro-5 class with his Mistang. He decided just to stop by for fun before racing at Heartland Park for a national meet. He assumed his motor was dialed in. When he hit 4,000 rpm, he was already way,.....lean. We went up three jet settings, adjusted timing and he put out 900 HP. He was extremely happy for two reasons, 1- he would have melted his engine being that lean. 2- we found 32 more HP just in simple tuning. We made 5 full runs and cost him $160 (2 hrs.) for shop time. Said he has $30,000 in the motor. He kissed me on the forehead for saving his engine !
Kevin
10-18-2007, 11:16 AM
Ill
We go to different dynos with our customers--they are excellent for being able to jet/time for max hp at max rpm---
I challenge any of you or for that manner, any rep for a dyno company to present a repeatable plan to adjust a carb for driving conditions---A car is not driven at wot on the street-----
The part throttle/ part load drive around is the best practical method to solve drivability problems that are not wot related---however it has its risks being on the road instead of sitting tied down on a couple of rollers
If you only got $160 for 5 runs and 2 hours time you should consider another line of work
Jerry
10-18-2007, 11:18 AM
Beam Me Up Scottie
MA
Kevin
As long as the kiss was on your forehead.
I was at a dyno shop with a bunch of Cobras a couple of years ago and the owner stopped a pull on one of the Cobras at about 4000 RPM. Just cheap $ pulls on a Sat morning with no tuning provided by the dyno shop owner. He said the motor was so lean, he did not want to chance blowing the motor. He told the Cobra owner to drive home, do not floor the gas pedal, and increase the jet sizes by 4 to 6 steps on primary and secondary.
Warren
10-18-2007, 11:53 AM
Ne.
Jerry- he is one of our sponsors on our sprint car so, $150 was cheaper for him. We don't overcharge our new customers. Because of that reason, we have four dyno nights per week. It brings in a lot of business. There is now way,......you can beat tuning on a chassis dyno ! You can even calibrate for weather conditions. If the operator can't tune your car for the street, you had better find a better one. There are some dyno shops out there that the operator is only a computer geek, not a mechanic.
Our Mustang dyno is a real world test, unlike the dynosport. The only changes after a dyno run you'll have to make is if the weather changes a great deal if you're racing or, a elevation change. We've had drag racers spend hours in the pits trying to find what the motor needs. They come to our shop for a dyno run and figure it out in one hour or less.
442- We also have a "dyno day" (the last was for all Mopars) and they were single runs for $50. It was a blast for all of us. Had pizza & soda (some had beer) Now, most want to come back to dial in their engines. That will be more $$$. We have all the jet's, spark plugs and distributer springs ect... to super tune most engines.
The dyno is good for our business as we don't over charge plus, "the word of mouth" for the dyno and our regular daily driver mechanic business is fantastic. We even put our sprint car on the dyno. Long story but, it was hilarious.
Kevin
10-18-2007, 12:57 PM
Renegade Nuns on Wheels
Oh
Pick up a holley tuning book. Set the total timing according to manufacturers recomendations. Set your idle speed. Check your initial, should be in the 12-14 range with that cam so long as it starts after a hot soak. Many are not curved right. Take the carb off and check the transfer slot. it should be exposed 'square' to maybe twice that (the book will explain it), if not, get it right and adjust the secondary butterflys by the amount of the front (ie 1 turn close on the front, one open on the back). Set your float height (up till it drips, down till it stops, that is max, do down from their for tuning). Set your idle mixture, adjust your accelorator pumps. Call me in the morning
10-18-2007, 01:01 PM
VA
Uhhh how about the main jets???? They are the key element of performance tuning. All this other stuff is just carburators 101.
________
________
10-18-2007, 01:05 PM
Ill
Guys
You can charge whomever you want whatever you want, I don't care
The dyno DOES NOT TELL YOU IF IT IS LEAN OR RICH---sparkplugs, O2 sensor,EGT tells you that---the dyno tells you hp/tq
Weather conditions-----unless you are having a very, very unusual day, the weather really won't affect the dyno portion but will effect the corrected numbers---------!!!!!!!!!
If the weather is way unusual, you shouldn't maybe be doing dyno pulls,,, go drink the beer and eat pizza
As for drag racers---yep the dyno can posibly help them for max power, where to shift, etc---but if you don't tow the car back to the pits, you will lose even more valuble data than the dyno results---plugs need to be checked every run for max performance, egt or O2 readings evaluated,etc
Cars that are on the TRACK can be tuned on a chassis dyno---one dyno we frequent is a Mustang for 1700hp and 200 mph or something like that--
I think that some of the dyno installations need more air supply as shortly the air is fouled and doesn't have enough O2, at least my eyes and nose hurts
And besides all that all the females wave at us out on the street ( Females Kevin!!!!)
Jerry
