  #21 (permalink)
Old 04-01-2009, 02:45 AM
PANAVIA's Avatar
I agree with the one piece push rod suggestion and having someone help you measure. Manley makes good push rods and they seem to be OK on the money -
ARP studs may not be a bad idea either , it may just be a bad stud. -- remember of your pushrods if too long or too short can also accelerate valve guide wear.
--Steve
  #22 (permalink)
Old 04-01-2009, 06:32 AM
zrayr's Avatar
Cobra Make, Engine: Fords
as mentioned above, there are probably several issues you need to address. Go step by step & make sure each component is fitting correctly before going on to the next step in assembly.
Z. Ray
'65 K code Mustang
'66 Galaxie 500
  #23 (permalink)
Old 04-13-2009, 10:58 AM
Cobra Make, Engine: A&C
I updated the Pull it thread here is the update on the push rod-stud problem.
After reading all the tips and searching the INTERNET. I bought harden push rods (stock length) like I should have. New ARP studs. Kept the stamped steel guides.
I reassembled the heads with the new studs. As I snugged down the studs I centered the rockers on the valve stems adjusting the guides. I rotated the engine over with felt marker color on the stem. Now the rockers are centered. I didn't realize that the guides holes that the studs go thru are over sized and adjustment are made by loosing the studs and re-torquing.
Over the weekend I've run some 50 miles and all looks good. I pulled the valve covers and no wear on the push rods.
I hope this help someone who might have the same issues.
  #24 (permalink)
Old 04-13-2009, 12:46 PM
zrayr's Avatar
unfortunately, life is a series of lessons, many learned the hard way. Good luck with your re-rebuild. I've got the same scars you do, only in different places.
Z. Ray
'65 K code Mustang
'66 Galaxie 500
Rate This Thread:
