Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > Standard Transmission and Gear speak with Jimi Guthrie
Old 08-09-2006, 07:40 AM
Jimi G's Avatar
Default Tremec Transmissions, TKO's, T56, T5, and all others
Hello club cobra members, I am here to help you with technical support and advice for standard transmissions and other drive train problems. Feel free to post any problems you might have. We are a Tremec transmission distributor, so that is what we specialize in, but we work on all types, so I am knowledgeable in all standard transmissions along with there individual parts.
My name is Jimi Guthrie and I will be monitoring this site, so feel free to contact me here, or by email at jimig@standardtransmission.com either way you will get a speedy responce.
Thank you,
Jimi G.
Old 08-09-2006, 11:58 AM
Cobra Make, Engine: Superformance Brock Coupe
Location? Badger
Old 08-09-2006, 12:15 PM
Jimi G's Avatar
Badger,
We are located in Ft. Worth Texas, but we ship all over the world.
Jimi G.
Old 08-09-2006, 03:46 PM
Jimi,
A few of us in Australia are looking for shift levers to suit a T56 Tremec six speed. I think Hurst have one that fits, not sure about others.
Do you have any, and if so at what price?
Ben
Old 08-14-2006, 08:28 PM
tamanaco's Avatar
Cobra Make, Engine: BDR #260 w/ 347 stroker, Canfield 195 cc heads, prosystems carb on a VicJr, Comp roller cam
Neutral
What is a T5 world class Tremec? It is being tied to a 345 HP ford small block, is this a good fit?
Old 08-14-2006, 11:25 PM
World Class? C'mon...a T5 is a T5. If it's blueprinted...sure it's better but it's still a T5. Yes, a T5 would be a nice trans' for a 345 BHP small block. It's lighter, smaller (shorter, so better prop shaft angle because the 'shaft is longer) and best..It's cheaper too! Badger
Old 08-15-2006, 07:55 AM
Jimi G's Avatar
A t5 world class is a little stronger, the version from Tremec is rated for 300 ft. lbs. of torque, and is a little cheaper that the TKO's and T56's. But, it is just not made to be drove real hard, they just won't take the abuse. If you need anything else just let me know.
Thank you,
Jimi G.
Old 08-15-2006, 08:04 AM
CobraEd's Avatar
the T5Z (aka Superduty T5) is only available thru Ford Racing as an aftermarket piece. It has stronger internals and a short throw shifter that is really sweet. It is rated at 330 lbft of torque. It has a 2.95 first gear as opposed to the regular T5s that have 3.25 first gear. This was done because Ford knew that this aftermarket unit would mostly go in performance cars with high rear end gears.
Here ya go:
http://www.jegs.com/webapp/wcs/store...tegoryId=10561
________
________
Old 08-15-2006, 08:49 AM
Jimi G's Avatar
That particular transmission is the same as the one I wrote about. You can find all kinds of torque ratings for these particular transmissions, but my figures come directly from Tremec. It has the 2.95 1st, 1.94 2nd, 1.34 3rd, 1.00 4th, and .63 5th, along with the Z gears. Drop me an email and I can help you out jimig@standardtransmission.com
Jimi G.
Old 08-15-2006, 11:17 AM
SJK2's Avatar
Cobra Make, Engine: SPF#2189
Jimi G,
Do you have any reports/feedback on TKO 600's sticking in gear.......
Old 08-19-2006, 08:24 PM
tamanaco's Avatar
Jimmy G,
can the t5 WC be converted to a 0.82 5th rear ratio?
Old 08-19-2006, 09:46 PM
Cobra Make, Engine: Cardiac, 428 FE
I have a Doug Nash 5 speed transmission that came in the roller I bought. Probably is over 10 years old and has Richmond on the side. What is this, exactly? The ratios are real close and the 5th gear is just a 1 to 1 ratio. I will not be racing this car so what am I giving up for the street?
The engine is a built 390 FE with about 425hp.
The rear end ratio is a 3.54 locker.
Who the heck is Doug Nash and why does the tranny say Richmond on the side?
Paul
Old 08-21-2006, 12:22 PM
Cobra Make, Engine: KMP
Jimi:
Do you guys have a shift knob that looks like the ones that originally came with the Toploaders in Cobras, but that shows the 5 speed gear pattern of the TKO 600s?
Lew
I'm no expert.
Old 08-21-2006, 12:56 PM
Paul Richmond gear bought out doug-nash about 20 years ago, it is an very good transmission, the gearing is 1st 3.27 2nd 2.13 third 1.57 forth 1.25 and fifth is 1.00 these are great with rear end gears from 2.75 to 3.25.
thanks Dean
RUMs are like a woman in Stiletto heals, you know they are going to put you in the poor house, but that has never stop anyone from pursuing one.
Old 08-22-2006, 09:42 AM
Jimi G's Avatar
T5...yes it can be converted to a .81 5th, but you have to install both 5th gears, which runs around $300 for the gears.
Kanuck is correct on the Doug Nash tranny, and also correct on the rear ratios to run with that particular unit. I would probably go with a 3.00 or higher so your rpms will be a little lower in 5th gear
As for the shift knob, we don't have anything like that, but you might check with the other kit car companies, because I believe I have seen something like what you are talking about, sorry I could not of been more helpful.
Hey guys sorry about not posting answers sooner, but it has been a mad house up here the past couple of days
Old 08-22-2006, 09:51 AM
I need a quote on a complete 5 speed, I'm thinking TKO. .8 OD, not TOO low on first gear. This older 'Hi Tech' brand Cobra is running a 3.5 rear gear, so I don't want 'stump pulling' gears in 1st and 2nd. By complete I mean gear shift, trans mount adapator that needs welding to round tube frame and whatever other misc pieces\parts required. Currently the car uses the typical external arm and classic throw out bearing setup and it's behind a 427 FE with a top loader. This is for a customer of mine, he wants it, I put it in, his car, his call. In Hawaii we don't see HIGH mph cruising speeds, with 60-65 being about average for a typical 'commute'.
Can you help? Feel free to e-mail me.
Old 08-22-2006, 09:52 AM
Cobra Make, Engine: Cutting Edge, Boss 429
Jimi,
What do you recommend for a lubricant in a TKO 600??
I have been told that I must use GM Synchromesh. What other products are as good or better?
Thanks for the help,
Chris
Old 08-22-2006, 11:46 AM
Jimi G's Avatar
Chris,
All we recommend is sycromesh, other fluids just don't seem to work as well in these units.
Jimi G.
Old 08-22-2006, 05:33 PM
Default Doug Nash/Richmond 5 spd
Kanuck or Jimi,
What I'm finding, now that I can finally drive this car, is that the ratios are very close and I can skip from 1st to 3rd with no problem. Would changing the rear from the 3.54:1 to something like 3.08 give me better cruise (noise, gas mileage too, as if I care, whoops.... do now), and better than crawler speed for 1st - 2nd gear? Exactly which ratio for the rear would you recommend? Since my engine is a 390 with about 425hp and torque slightly less (guessing), it isn't going to perform as good with a 3.08 as it does now, right? How much of a performance hit will I take in going to 3.08 rear ratio?
Thanks, Paul.
Old 08-23-2006, 03:17 AM
Paul as they say it would be "much more better" with the 3.08s or even higher, 2.88 if you have a jag rear or 3.00 with ford 9in, my best choise would be a 2.75 then you could use every gear to it's full potential. I have used this combo in a car with less hp and more weight than you have currently with great results, that range is exactly what they are built for.
thanks Dean
