2Likes
05-25-2007, 09:15 AM
Cobra Make, Engine: SPF 2293, Roush 427R-228
seeking advice on shifter upgrade
For a TKO600 w/.82 OD. This is in a Superformance with a Roush 427R windsor stroker.
Basically I can't hit the 2-3 shift under full acceleration to save my life on this tranny. I swapped out the traditional looking reverse lockout shifter for a Jordan shift lever and it's a little better, but I think I need to install a new shifter.
I'm looking at either the Pro 50, or the Steeda Tri-Ax unit. I had a Pro 50 on an a very early TKO in a blown mustang 5.0 and was happy with it, but I've also heard good things about the steeda unit.
Any opinions one way or the other? Jimi does Standard sell either unit? If I'm taking your advice I'd like to give you the business, only seems right
Daryl
05-25-2007, 11:35 AM
I had the same problem. Replaced the shift tower to the Pro, and the shift lever to the Jordan. It seems alot better.
Scott
05-25-2007, 11:46 AM
VA
My son had the exact same problem with his T56 in his Cobra Mustang. We put a Hurst shifter in it and now the 2 > 3 shift is a breeze. Plus 30% shorter throws overall.
________
________
05-25-2007, 12:22 PM
Just curious. Can you access/install a shifter kit from inside the car or do you need to drop the trans?
05-25-2007, 12:25 PM
VA
On most cars, you do it right from the inside. 4 Bolts, . . . Piece of cake!
________
________
05-25-2007, 01:18 PM
On my SPF, I had to take the new Pro 5.0 shift tower apart, loosen the rear trans mount bolts so I could move the trans to the side a bit. It was a bit of a chore.
Scott
05-25-2007, 02:22 PM
Tx
In my opinion the Steeda Tri Ax shift top is one of the best on the market. As it was stated above it gives you a 30% shorter throw and a more positive shift feel from 2nd to 3rd. I am in the process of bring in a line of aftermarket shift tops I just have to cut through all the red tape first. jimig@standardtransmission.com
True friendship is like peeing your pants, everyone can see it, but only you can feel its warmth.
Plan your life like you will live to be 120 years old...Live your life like you could die tomorrow.
09-11-2013, 04:54 PM
ny
shifter upgrade
ok.. used the search function and came up with this older thread.
Looking at doing the same upgrade for the same reasons in my SPF.
Anyone care to chime in with likes? Dislikes? Success with any particular product?
Thanks!
B
09-11-2013, 05:51 PM
Vic
The advise given to me by a prominent engine builder and parts supplier was go with a Steeda Tri-AX if matched to a TKO600.
09-11-2013, 06:16 PM
ny
tranny badge
tranny id
09-11-2013, 07:18 PM
The shifting problem is internal to the TKO500/600 transmissions. Liberty offers a shift kit that requires a little effort to install but is definitely doable at home (you do need to get the trans out of the car and apart).
If you are squeamish about the inside work on the trans, Liberty will install it for a fee. They call it an internal shift linkage upgrade. While you are at it get the carbon fiber faced synchro rings, bronze shift fork pads, and threaded front cluster bearing support to compete the package. You'll be glad you did.
Ed
09-11-2013, 07:23 PM
IA
MGW shifter. Hands down the best you can buy.
09-11-2013, 07:25 PM
Full Blown Member
Ed is right.
My next TKO will be through Liberty Gears.
rodneym
09-11-2013, 07:27 PM
ny
.. so i m confused..
will updating the shifter not help the tranny?
09-11-2013, 08:51 PM
The Tri-Ax will help reduce mis-shifts from 2nd to 3rd. I didn't like the transmission at all when I first got the car. it seemed quirky and hard to shift. After years of driving the car, the shifts seem effortless.
Doug
09-12-2013, 06:08 AM
VA
I have had a TKO 500 and 2 TKO 600 .82s in my 427R SPF. My experience is that a shifter will not fix a TKO. I am using a Pro5 with a Jordan arm and I think it is as good as it's going to get...which isn't great. The 2/3 shift at 6000+ rpm is not reliable in my car. I have just bought a new, modified 600 from these folks: WELCOME TO LIBERTYS HIGH PERFORMANCE. The car is in Dennis Olthoff's shop for some major work and will have the new transmission installed when I get it back in about a month. I will post my impressions after I have put a few miles on it. I am guardedly hopeful.
09-12-2013, 03:51 PM
RI
I have the Tri-Ax and really like the strong 2nd 3rd lockout. The stops are well constructed.
I have the 3550 Tremec and don't miss any shifts. I will say it's harder to hit the power shift with the wheels spinning. I have heard (and read it on this and other forums), the Tremec likes the GM syncromesh fluid and it helps with the shifts.
Lou
09-13-2013, 02:58 PM
Blocker rings are the answer for missing gears. Here is an excerpt that explains and a link to the entire article:
According to Hanlon, the blocker rings are essentially the same basic design from the '60s-era Top Loader transmissions. The Hanlon Motorsport friction-lined rings were designed out of necessity. "As the horsepower and torque has increased dramatically, the transmissions need to be stronger and include heavier gears to withstand the power. The heavier gears have more inertia, so it's harder to slow down those bigger and heavier gears. The lined rings slow the gears down quicker to allow them to engage easier."
Read more: Hanlon Motorsports Tremec TKO-600 Transmission - Muscle Mustangs & Fast Fords
I just bought a TKO 600 from Bob Hanlon (he's in Elverson, PA just NW of Philly). Nice guy to deal with and obviously knows his stuff. I have his phone number and address if anyone is interested. He said he and Liberty get the blocker rings from the same source, so they are the same - just a matter of where you want to get them.
Kevin
09-13-2013, 05:31 PM
Just go Hurst and call it a day.
09-14-2013, 12:25 AM
My prediction is that you are going to be very happy with the Liberty version of your TKO 600. If you did the upgrade and removed the old pieces, compared them to the Liberty replacements and how they worked / were timed, you would have no doubt in your mind about where the problem lies.
This is a Tremec issue yet again and right on par with their third gear mainshaft / countershaft misalignment that precipitates the premature third gear failures. Good shifters can mask the 2 - 3 shifting problem somewhat but they can not correct the bad internal design of the shifter rails. Liberty's upgrade does!
Ed
