December 2025
Old 11-01-2010, 09:12 PM
mattpatt's Avatar
Cobra Make, Engine: Superformance SP3033, KC SBF 427
Default Clutch slave settup for 351W
My SPF cobra is on its way and I'm preping the engine, etc. The engine is a 351W based aluminum DART block. It will have a T56 Magnum with QuickTime bell. I understand that the pivot is on the passenger side and will require either a puller slave from the engine side or a pusher slave from the tranny side. Do any of you have any recommendations for the slave and bracket settup that works best?
Also - any recommendations for the starter motor?
Any info is appreciated.
Old 11-02-2010, 02:46 AM
Matt, I also carry a few different brands of starters. I like the CVR gear drive starters. They will pivot along their axis so that you can mount them in a way that gains the most clearance for the connections. They have a 4:1 drive so they will start any engine. They're just under $200.
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
Old 11-02-2010, 08:49 AM
Blittleton's Avatar
CC Member / Sponsor
Default T-56 Slave cylinder
I have built several brackets for transmissions, but I really like to use the HTB with the 6 spd trans. I only use tilton HTB's.
Bill
Squeaky wheel always gets the grease!!
www.gcperf.com
