January 2026
4 5 6 7 8 9 10
11 12 13 14 15 16 17
18 19 20 21 22 23 24
25 26 27 28 29 30 31
  #41 (permalink)
Old 01-21-2011, 06:10 PM
I have watched the video about 150 times, he boils those tires, god bless him.
  #42 (permalink)
Old 01-21-2011, 07:02 PM
Chaplin's Avatar
Cobra Make, Engine: Original ERA 427sc, Powered by Gessford
Originally Posted by madmaxx View Post
I love this combination and it will be my next Cobra. The benefits of modern fuel injection, reliability, driveability and probably pass emission if you had to. Car sounds great, not as throaty as a pushrod engine but very very few would notice. Looks great in the engine compartment. I dont think it can get any better.
Ditto to the above.
Replica is not a dirty word.
  #43 (permalink)
Old 01-21-2011, 07:49 PM
CobraEd's Avatar
Looks good in the engine compartment.
LIFE IS TOO SHORT TO WORRY ABOUT GOOD GAS MILEAGE
________
Utinam logica falsa tuam philosophiam totam suffodiant!
________
  #44 (permalink)
Old 01-21-2011, 07:58 PM
CobraEd's Avatar
Default Lopy idle / 110 ft burnout in third / Drag radials
Cobra:
http://www.youtube.com/watch?v=a0oozO1Rg1k
________
________
  #45 (permalink)
Old 01-21-2011, 07:59 PM
tin-man's Avatar
Cobra Make, Engine: SPF2984 MK111, Roush 511 IR FE 8 Stack, Dynoed: [flywheel] 572HP at 6000 , 556# Torque at 4700, Bowler 4R70W Auto Transmision. Tires: Mickey T's S/R 26.0x10.0x15.0 F ,26.0x12.0x15.0 R Color, Bleck, because they told me it was Bleck, at the factory.
Default Patrickt I need a favor
Originally Posted by SunDude View Post
Here's a nice video with Lance showing how the Coyote-powered MkIII sounds and goes... fabulous!
Patrick, I am back in China and cannot get Utube since its banned, could I ask you A REALLY big favor to work your computer magic and transfer this vid to a vid so that those who cannot get UTube can see and enjoy the moment......? John, AKA, tin-man
Be well, drive fast, live long
  #46 (permalink)
Old 01-21-2011, 08:08 PM
fordracing65's Avatar
the dohc motor from ford is nothing new, im amazed how everyone thinks this is some kind of new technology, my motor puts out 400 to the wheels, fully forged, all aluminum, great mpg, has a unbelievable track record. coyote only races in one class, ford dohc have been dom inating for years.
  #47 (permalink)
Old 01-22-2011, 07:09 AM
CobraEd's Avatar
nice technique get into 2nd, that would probably help me from spinning 360 degrees and floating off the road.
Max, What he did is called "Short Shifting".
________
________
  #48 (permalink)
Old 01-22-2011, 07:24 AM
mickmate's Avatar
If it didn't wheelspin it would have daylighted the front tires, in first and second. It really hikes those things.
mickmate
http://www.actoncustom.com/
  #49 (permalink)
Old 01-29-2011, 08:51 AM
digginfool's Avatar
Cobra Make, Engine: Backdraft #880, Ford Racing 392 w/4 - 48IDA Webers, TKO600
Originally Posted by CobraEd View Post
Its smooth quiet idle is due to the cam. Too bad.
The gross duration on the lobes and the lobe separation angle between the lobes are what gives the lumpy "Cobra like" idle. This is an emissions engine and cannot have that.
The 'lumpity-lump' of a high-performance cam comes from the overlap ground into the cam to optimize high RPM performance. Overlap is the amount of time both the intake and exhaust valves are open. At high RPM, it maximizes scavenging of the exhaust and filling the cylinder with the air-fuel mix. At low RPM, excessive overlap creates that 'lumpity-lump' idle we've all come to love. The Coyote has variable cam timing. At low RPM, the cams roll out to reduce overlap and create a smooth idle and manageable power delivery, not to mention an environmentally cleaner exhaust. At higher RPM, the cams roll in, increasing overlap which creates more horsepower. Without the variable cam timing, you would have the power the idle suggests. The beautiful thing about these new motors is with the mass flow and O2 sensors, you will have optimum fuel delivery to maximize efficiency and thus power. Want more power, just add air. The computer does the rest.
  #50 (permalink)
Old 01-29-2011, 08:18 PM
Nice explanation, the coyote motor is a no brainer unless you are an old fart trying to relive your youth with the smell of gasoline and chokes I have to get one!!!
  #51 (permalink)
Old 01-29-2011, 08:44 PM
Just change the cams, you can make it sound any way you want, Ford builds these motors for daily drivers, its our job to modify to our specs. (Lumpity lump)
  #52 (permalink)
Old 01-30-2011, 05:45 AM
digginfool's Avatar
I'd rather add air than mess around with cams and computer programming. I'm sure some company will eventually offer something but look at it this way; Coyote... $6,500.00
Ford Racing Coyote Supercharger w/bigger injectors... $7,500.000
$13,500.00, 650 HP Motor for your Cobra... Priceless!
