Like Tree1Likes
Old 04-19-2011, 07:40 AM
Jake's Avatar
Cobra Make, Engine: Superformance Cobra #1628, Coast Performance Stroker 427W Ford 520HP/535FT.TQ, Blue with white stripes
Default Air Conditioning in SPF
Just got a new Superformance and the prior owner put Vitage Air in it. The AC works great and blows really cold. My question is does anyone have any ideas of how to clean up the install and make it look better. Any pictures of a clean install would be great. I have included a pic of the train wreck that I am dealing with.
Thanks, Jake
If your going to dream, dream big!
Old 04-19-2011, 08:07 AM
Cobra Make, Engine: Superformance #848 351W/396
The first thing you should do is add another throttle spring.
John
Old 04-19-2011, 08:50 AM
Blas's Avatar
Cobra Make, Engine: SPF#0760
Probably replacing all the silver material with something black would visually helpful. Especially the aluminum "dryer vent" across the back firewall. Perhaps a sheet of carbon fiber or just a dress-up aluminum plate on the side, Consider the header heat when picking materials.
One other thing, check the mounting of your coil. I believe that type should not be mounted in the horizontal position.
SPFWiringDiagrams@Comcast.net
Old 04-19-2011, 08:56 AM
Jerry Clayton's Avatar
Move the a/c unit to the trunk and if every body gets to be pickie---those are the wrong distributor cap wire ends for those hold down plates---
Old 04-19-2011, 09:24 AM
Zoom This's Avatar
Jake....Looks like it's going to be difficult to dress up the AC install with it being so crammed into place. Did the car come with a hard top? If not, AC in a convertible in Western Wash. does seem a little out of place. Cobras don't have much room for add-ons as you probably already have witnessed. Don't know how effecient the AC will be on a hot summer day, AC blowing on your legs, chugging around town with so much under hood heat. Best of luck with the project.
Bill
Old 04-19-2011, 10:44 AM
ItBites's Avatar
Cobra Make, Engine: Midstates, Vette suspension, Baer 6P brakes, 540 cid Chevy, Haltech Fuel Injection
How about move the blower and heat exchanger under the dash, behind the firewall?
I had AC on mine years ago and that is what I did. The only parts under the hood were the compressor and the dryer.
Ajeagle6921 likes this.
E. Wood
ItBites
10.69 @ 129.83mph - on pump gas and street tires
Old 04-19-2011, 11:47 AM
Jake's Avatar
I agree 100% with your comments. That was what I was thinking. I just wanted to see if someone might have an idea that I did not think of. I like the carbon fiber idea. Any ideas on a different type of black tubing? It has 6" with insulation and then 4" tubing inside that.
Jake
Old 04-19-2011, 11:48 AM
Jake's Avatar
Not a option as we take week long trips in the car and need all the trunk space we can get.
Jake
Old 04-19-2011, 11:49 AM
need to mount the coil vertically
Old 04-19-2011, 12:52 PM
VintageUpgrades's Avatar
Cobra Make, Engine: Auto Restoration and Service
Can you pull back the aluminum shielding and let us see what is under there? Is your factory heater still hooked up under the dash?
Mitch
Old 04-20-2011, 08:08 PM
Cobra Make, Engine: Superformance 427R
Looks like all the air from the evaporator goes into the driver's footwell. Maybe you could route that big dryer tube into the passenger footwell and split it into smaller tubes feeding outlets on both sides of the car.
Old 04-23-2011, 05:22 AM
Jake's Avatar
I have been crazy busy and unable to get more pics taken. There are now 2 round vents that spin in the driver area. Onr just in front of the shifter and one below my right knee attached to the tunnel. The dryer tube goes behind the engine and then over the bell housing where it splits into 2 pieces to attach onto the vents. The car has a glove box so there is zero room to add anything under the dash.
Jake
Old 04-24-2011, 08:20 PM
I'd remove all the A/C components completly and go with the standard 2-80 model. End of problem...
Old 04-26-2011, 06:13 AM
Absolutely!
David
Old 04-26-2011, 06:25 AM
392cobra's Avatar
6th Generation Texan
What he said.
I can kinda,sorta,maybe see it in Texas BUT Washington.
Pretty stupid.
Old 04-28-2011, 08:14 PM
Mark Brye's Avatar
Cobra Make, Engine: BDR354/FMS392
Jake, I bet Ray could help you with that!
Old 04-28-2011, 09:42 PM
That's where the Kenmore dryer is. Sorry Mike, couldn't resist.
Old 04-29-2011, 05:00 AM
Jake's Avatar
It is good to see you are still alive Mark. I bet Ray would be up for the challenge. I hope to see you this spring and summer on some drives. Let's go blow through some $5.00 a gallon gas.
Jake
Old 05-01-2011, 11:10 PM
I have A/C in my Backdraft. The unit was installed in my trunk against the
wall between the trunk and the seats. The battery that was there was moved to the rightside fender well. I made plexiglass windows that fit in the door and a have a bimini top and a fine screen windbreak for the roll bars and between them, with all this on it keeps it pretty cool.
Old 05-03-2011, 10:31 AM
PANAVIA's Avatar
The engine bay photo just sends sudders up my spine, like those web sites "ifixeditrealgood.com" or something similar.
next up -- plywood sidepipe hangers.
