Old 02-20-2011, 04:47 PM
Default Winter project on my SPF
I got tired of looking at the cheap plastic clutch fluid reservoir and the difficult location of the plastic brake reservoir.
Parts:
- Reservoir cans (Kirkham Motorsports)
- Mounting bracket (Olthoff Racing)
- Braided line kit (Olthoff Racing)
Definitely a two man operation, can be done entirely from the topside of the car and we didn't even need to bleed the brakes or clutch slave after.
Old 02-20-2011, 04:48 PM
looking good
sdr
Old 02-20-2011, 06:02 PM
Blas's Avatar
Cobra Make, Engine: SPF#0760
Nicely Done Brian...Looks a lot better then the plastic.
SPFWiringDiagrams@Comcast.net
Old 02-20-2011, 07:20 PM
67JET's Avatar
Cobra Make, Engine: Holliday Motorsport/396 GM / 4 speed / Jag rearend
Looks Good!
I'm thinking about changing my gas peddle linkage to rods like yours. You got any more photo's of your gas peddle and linkage?
Old 03-03-2011, 06:05 PM
Originally Posted by 67JET View Post
Looks Good!
Old 03-06-2011, 07:29 PM
Real nice, I have the reservoirs on order from Kirkham. Thanks again for the info and great pics.
John
Old 03-07-2011, 04:04 AM
Cobra Make, Engine: SPF 2234 Diamond Edition, Roush 427R
Looking great!!!!
Was buying the cans from Kirkham last year - seems you was faster with the install. First i thought i would go with rubber hoses but after seeing yours i will use braided hoses too.
Winter is allways a busy time...some actual projects on my SPF
- replacing the plastic reservoirs
- new billet clutch slave cylinder bracket
- new valve cover gaskets
- rear fog lamp
- rear backup light
- new seat spacers for the driver seat
- headlamp warning buzzer
- Hella Headlights
Hate our long winters but this helps to do some work :-)
Peter
Old 02-20-2011, 07:26 PM
fordracing65's Avatar
How can you tell how full they are without taking off the cap?
PRIDEnJOY
Old 02-27-2011, 06:09 PM
Flyin_Freddie's Avatar
Cobra Make, Engine: Superformance #770, Stroked 351W (393 cubes) w/ Tremec TKO-600, 3.27 Torsen locker, 'Hi-Tech' Blue w/ White Stripes, Wilwoods, Bilstein coil overs...and a big ear-to-ear grin!
Default Are you serious...?
Originally Posted by fordracing65 View Post
how can you tell how full they are without taking off the cap?
You have GOT to be kidding ...
Flyin_Freddie
"An opinion on everything...an expert at nothin'!"
WARNING: The opinions expressed herein do not necessarily represent those of the management, editors, or owners. We welcome differing opinions, and recognize our responsibility to offer differing views. May cause drowsiness, restlessness, or irritability. Do not operate heavy machinery while using this product. Void in Alaska, Hawaii, and Puerto Rico, or where prohibited, licensed, or regulated by law. We reserve the right to limit quantities. Offer good while supplies last. No substitutions allowed. Please observe posted speed limits. Professional driver on closed course. Do not try this at home. Please wear your seatbelt at all times. Close cover before striking. Use at own risk. Please dispose of properly. Drink responsibly. Prolonged exposure to vapors has been shown to cause cancer in laboratory animals. Do not use this product of you are pregnant, or plan on becoming pregnant. Intentional misuse by deliberately concentrating and inhaling fumes can be dangerous. Always wear safety glasses. In case of eye contact, flush with water and seek immediate medical attention. For occasional use only as directed. Avoid prolonged skin contact. Discontinue use if rash develops. If symptoms persist for more than three days, seek professional medical attention. Hearing protection required beyond this point. Danger: Hot surfaces. Use as directed. Proceed at own risk. Caution: Filling may be hot. Please don't litter. Actual results may vary. It is a violation of Federal Law to use this product in a manner other than as intended. Do not use this product if you have an enlarged prostate, or have difficulty urinating.
Old 02-20-2011, 08:01 PM
Cobra Make, Engine: Superformance SP02423 KCR 445W 611hp 599ft lbs
Brian..I need to give you a call. With my motor out it would be an easier conversion. I like it!
Old 02-21-2011, 05:37 AM
Blas's Avatar
I know where a linkage setup in available...PM me.
Old 02-21-2011, 07:19 AM
Fantastic!!!!! I get much more enjoyment from my plastic one that I used leak seal around the bottom to stop it from leaking. Most that see it ask what is smeared on the bottom of mine, turns out to be conversation piece, similiar to the plastic oil line that came with it. Yours looks professional, fitting of a $40k plus roller, or should I say $40,500 roller. Great work!!!!
Old 03-03-2011, 11:51 AM
Real nice. I've been looking to do the same on 1134. Does the attachments to the brake master cyclinde come with the braded lines and what is the cost of parts? What short cuts did you learn during the install.
Thanks
John
Old 03-03-2011, 04:14 PM
Cobra Make, Engine: Midstates 427 / ERA 289 USRRC
Were you able to mount it higher than the Brake master cylinder? What did you use to connect the resorvior line to the master cylinder? Any pics of this? Looks nice
Old 03-03-2011, 05:58 PM
Thanks
John
Hey John,
Dennis Olthoff sold me a complete connection kit for the reservoir assembly. It came with the following:
2 - bungs to go into the master cylinder ports
2 - 90 degree elbows (screwed into the bungs and allowed for braided lines to attach)
2 - braided lines with flare fittings to attach to the canisters/elbows.
1 - nipple to fitting to attach the clutch hose to the braided line back behind the power booster
1- braided line to attach to the clutch canister/nipple
1 - quality hose clamp
http://www.olthoffracing.com/
150 Cobra Lane
Mt. Ulla, NC 28125
704-647-9924
Were you able to mount it higher than the Brake master cylinder? What did you use to connect the reservoir line to the master cylinder? Any pics of this?
Hi Mike,
Yes, the canisters are definitely higher than the master cylinder.
Attached is a picture of the master cylinder connections.
Old 05-24-2011, 10:40 AM
when you mounted the cans did you use the bracket dennis sent and if so did you drill two holes or four in the fire wall?
Old 05-24-2011, 11:23 AM
John,
I drilled 2 holes on either side of the rivet located on the firewall. There is a 2" x 1" square tube behind the firewall in that location. You can locate the cans in the center of the firewall but do make sure you leave enough clearance for your throttle linkage. I made sure there was 1/2" between the closest canister and the linkage assembly.
Take care when drilling as the heater core is just beyond that tube!
