| 29 |
09-16-2011, 11:58 AM
GEAR GRINDER CUM LAUDE
KY
Cobra Make, Engine: SPF #1560 w/ Ford Racing [RDI/AFR/RPM] Alum. 427CI - 575HP & TKO
shifter boot replacement
Has anybody changed out their shifter boot? I have a new one from Finish Line that I want to install, but looking at the situation this AM, it appears that I need to remove the whole shifter from the transmission, as the phony reverse lockout doesn't want to move and let me slid the old boot off and replace with the new. Any suggestions?
TL
BOYZ and TOYZ
With every day I grow alittle older -
BUT, I'LL NEVER GROW UP!
09-16-2011, 01:41 PM
Senile Club Cobra Member
Undo the bottom of the boot and ring, lift it and unbolt the shift handle from the shifter assembly. On TKOs the lever will unbolt. The handle is usually afixed with a Torx head bolt.
rick@autoventureusa.net
09-16-2011, 03:09 PM
IL
Un screw the shifter knob, there is a set screw down the center holding the fake reverse lock out.
 Time to paint the street!
09-17-2011, 11:21 AM
KY
Got-r-done
Thanks guys,
It was easier than I thought. The set screw takes a 5/32" allen wrench.
The new boot has depressions for the screws that hold the finish ring in place = I drilled mine out so to line up with the existing holes in the car.
Blas,
Thanks for the PM; we went out for dinner and didn't get back until late.
This is why Club Cobra is So Great!
TL
BOYZ and TOYZ
09-25-2011, 10:44 PM
Tn
Cobra Make, Engine: Superformance#2352/Aluminum SO/490 c.i. 650 h.p. 605 tq.
Where did you get the shifter boot. Mine has a slight tear in it
09-25-2011, 10:53 PM
Cobra Make, Engine: SPF #1473 392 cu.in. titanium/black stripes
Try Hillbank, Finishline, Cobra Restorers...
"Outside of a dog, a book is man's best friend. Inside a dog it's too dark to read."
Groucho Marx
09-25-2011, 11:32 PM
Tn
Thanks, have to go up to Hillbank this week, and will pick one up then
09-26-2011, 04:23 AM
ON
I replaced the rubber shifter boot on my SPF last year. For about a month afterwards, the rubber was so stiff that it would occasionally pop the shifter out of 3rd gear. It eventually softened up and the problem has since gone away, but be prepared for this when you're done.
09-26-2011, 04:53 AM
UK
Mine's still doing that after 3 years, mostly on the over-run.
Paul
09-26-2011, 06:35 AM
KY
If your shifter is popping out of gear; you might want to try and flatten the boot down a bit. Once it gets past the bend in the shift handle, it should not be a problem. Having said that, I haven't driven my car since installing the new boot.
To many other things to do my cheerleader says.
TL
BOYZ and TOYZ
09-26-2011, 12:11 PM
Cobra Make, Engine: SPF#0760
Shifter Boot (FORD #C2AZ-7277-A)
1962 1963 Ford Galaxie and Full Size Models 1962 1963 1964 Ford Falcon
Ford Shift Boot, Falcon, Fairlane, Galaxie, Ranchero, 1962-1968 - Ford Parts
$24.95
When replacing the boot you can sometimes make a little adjustment to the location of the trim ring by making new holes in the tunnel. This will move the boot so equal pressure is exerted on the shifter. I've seen a few tunnels with the shifter hole seriously offset position from the actual shifter. Centered is the prefered installation, with equal rubber boot resistance in the forward and reward gear positions. The alternative is the leather or NOMEX shifter boots if you offset is extreme......
SPFWiringDiagrams@Comcast.net
09-26-2011, 05:39 PM
Cobra Make, Engine: CSX 2252 sold 3-08, 1986 AC Cobra MK IV #185
Does anyone reproduce the shifter boot without the mold line on top?
10-03-2011, 10:34 AM
Cobra Make, Engine: SPF roush 402
$24.95
Thanks Blas you just saved me 10 bucks.
10-03-2011, 11:48 AM
ny
Cobra Make, Engine: Gary Edwards Racing 460
Me too. Thanks Blas!
Its not the will to win that matters....Everyone has that. Its the will to prepare to win that matters.
11-11-2011, 05:28 PM
Finish lines sells for $25.00
