06-01-2012, 02:51 PM
I imagine all all affected. As Blas explained, the cable terminal is under stress then as the body flexes failure will occur. Solution is simple, enlarge terminal hole to slot so the terminal is not under bending stresses. Remember same current that goes through positive goes through negative, I guess worse case scenario is you catch carpet on fire from hot terminal.
