Old 02-05-2013, 01:46 PM
mickmate's Avatar
Default Windsor to FE repower
Anyone done this with their SPF? It looks like bolt in motor mounts? FE headers fit the sidepipes? Must need a bigger trans than the T5? Anything else I need to consider and price? Thanks for any input.
mickmate
http://www.actoncustom.com/
Old 02-05-2013, 02:04 PM
Cobra Make, Engine: factory five mkIII roadster 445 fe quick fuel 750 q series,irs
I just changed my ffr from a 342 to a 445fe, spf may be different but i had to get a new driveshaft, the hole for your shifter may be off, possible radiator?
i have irs and i was already running 600 pound springs front and rear but the egine in a ffr sits behind the front suspension. i am still running my tremmec 3550 trans ok so far.
factory five mk III roadster, 445 fe stroker
Old 02-05-2013, 05:14 PM
roadrod2000's Avatar
Cobra Make, Engine: Unique 289 FIA HiPo 289 with Shelby dual quad intake
Bell housing bolt pattern will be different
Rod
Old 02-05-2013, 05:19 PM
Senile Club Cobra Member
Nick,
Different engine mount pedistals and the standard different items between Windsor and FE (slave cylinder, etc.) T5 is a non-starter but any TKO is good. I have a set of SPF FE headers on hand...the side pipes are the same. Call if you need more info.
rick@autoventureusa.net
Old 02-05-2013, 05:54 PM
racco's Avatar
FE or go home
Old 02-05-2013, 06:03 PM
mickmate's Avatar
Thanks Rick I'll call and chat with ya about it.
Home?? Where does a man without a country call home?
mickmate
Old 02-05-2013, 06:47 PM
racco's Avatar
all you need down there is a green card
