Old 07-11-2013, 11:57 AM
Cobra Make, Engine: Backdraft #90, 351w,Tremec 3550, SB100 SOLD
Default Superformance starting procedure
Superformance owners,
I need your help. We are going out to do a presale inspection on an older Superformance (built 1996) car. The owner said the starting procedures are a bit unusual. Can anyone let me know what to expect? Or what exactly is the procedure?
Thanks,
Skip
Old 07-11-2013, 01:49 PM
Blas's Avatar
Cobra Make, Engine: SPF#0760
Unless the owner has installed a hidden kill switch(s) or something, you pretty much get in, pump the gas pedal once or twice (carbureted engine) and turn the key. If a push button starter was installed you insert the key and turn to position #1, pump the pedal and push the button. Perhaps he is referring to an engine without a automatic choke, in which case you keep it running for a min or two with the gas pedal....
Or maybe you turn the key and need to pray it starts?
I can't wait to hear what you needed to do to start it.....
SPFWiringDiagrams@Comcast.net
Old 07-12-2013, 08:56 AM
DanMartin's Avatar
Cobra Make, Engine: Superformance Cobra Chassis #408, 427FE, TKO600
Blas has it right...that's all I do (well, after taking a few minutes to snug up the Simpsons).
1996? What is the chassis number?
Dan
Old 07-12-2013, 08:58 AM
Mark Brye's Avatar
Cobra Make, Engine: BDR354/FMS392
Depending on the car, there could also be a battery cutoff switch and also a fuel pump switch if these are disabled when car is parked
Old 07-12-2013, 07:31 PM
Cobra Make, Engine: Superformance #2689 Roush 427R TKO 600
Make sure it is in nutral or it won't crank! (Nutral start switch)
B i l l
