Old 10-06-2015, 09:32 AM
Default Fuel Pump
The carter pump in 1764 seems to be on its way out...i was thinking about going to this:
Stewart Warner Electric Fuel Pumps 82089 - Free Shipping on Orders Over $99 at Summit Racing
I have heard some horror stories about holley and moroso pumps.
The description of the SW pump seems like it is pretty stout and at 7psi shutoff pressure wont flood out my Holley 850...Also it is Very self priming so that's not a problem either.
Thoughts?
Superformance 1764
Built 427W
Aiken SC USA
Old 10-06-2015, 09:44 AM
Edelbrock fuel pump part# 1792
Most reliable pump i have ever had.
Old 10-06-2015, 10:24 AM
how/where did you mount that thing?
Superformance 1764
Built 427W
Aiken SC USA
Old 10-06-2015, 11:15 AM
Mounts where pump mounted now.
Just forward of fuel tank on frame rail
Comes with rubber isolating metal bracket
Old 10-06-2015, 06:16 PM
Default Any chance you have a photo?
And maybe a short narrative on installation (assuming you are a DIY'er like me)?
Superformance 1764
Built 427W
Aiken SC USA
Old 10-07-2015, 07:52 AM
-drill and tap frame to accept mounting bracket that comes with pump.
-the in and out line openings on pump are located on the same end so you will have a direct connection to the in but the out will need a u shaped connector to get you in the forward direction from the out line of pump back to main fuel line along frame.
Old 10-07-2015, 07:54 AM
Old 10-07-2015, 08:29 AM
forgot to mention that you might be able to use the same drilled and taped mounting holes of the previous pump bracket.
Old 10-12-2015, 10:03 AM
Thanks!
Superformance 1764
Built 427W
Aiken SC USA
