Old 03-27-2016, 08:13 PM
Default Shoulder Harness upgrade
Looking to upgrade my car with shoulder harness. Only has the lap belts. SPO#2811. When going thru the wall behind the seat, is there one attaching point or two for the shoulder belts? Want to get it right the first time. I've seen both the double shoulder belt and one that goes over both shoulder and looks like a "Y".
Old 03-27-2016, 08:50 PM
DWRAT's Avatar
On my car there is one attachment point per seat.
Y harness in my car.
FFR MK1---Sold
Superformance #884 --- Sold
No more Furds.
Old 03-28-2016, 03:16 AM
Sawdust's Avatar
On #1950 there is only one attachment point per seat
Old 03-28-2016, 04:10 AM
Cobra Make, Engine: SPF Coupe #136, 427SR FI
The guys are correct - single bolt thru. There is a vertical piece of steel on the back side of the cockpit. Check it out with the car on a hoist. That is what you want to bolt thru. Be sure to measure both sides as the body could be a little off center when secured to the frame and since that is not a wide frame part you could miss center of it.
I used a marine grade eye bolt with fender washers.
Jeff
Old 03-28-2016, 01:40 PM
Blas's Avatar
Cobra Make, Engine: SPF#0760
I can send you directions for installing the "Y" shoulder harnesses. Going to 2 belt connections will take modifications or the addition of a crossbar on the hoop. My email is below.
SPFWiringDiagrams@Comcast.net
Old 03-28-2016, 08:39 PM
I'll take any info I can get and appreciate it. My email is brdslayr@charter.net Hopefully I can find a part number and just buy the shoulder part of the harness.
Old 03-29-2016, 04:09 AM
Sawdust's Avatar
I got my shoulder harness from DJ Safety Inc. I believe the part number was "330300" which is a 3" "Y" black style harness. Give them a call
Old 03-30-2016, 05:42 AM
Blas's Avatar
Install info sent.........
Old 03-30-2016, 10:11 AM
zedog's Avatar
Cobra Make, Engine: Superformance SPO3058, Roush 427SR-TW
DJ sells them without their logo too, just have to ask.
Old 03-30-2016, 12:18 PM
Tim7139's Avatar
Cobra Make, Engine: Superformance #2660, FE-406
When you get the ass end up and wheels off, you can see the hole in the frame and locate the slot in the bulkhead behind the carpet. Slit that with an exacto knife.
You want a harness set with a single metal bracket, which you bolt up through the cross member. i think I used a grade 10 5/16" bolt and large washers with a lock nut. Takes about 10 minutes a side.
Did mine the same time I installed the shock mount upgrade, last summer.
The older I get, the faster I was.
