Old 06-06-2016, 08:16 AM
Tim7139's Avatar
Cobra Make, Engine: Superformance #2660, FE-406
Default SPF indicator lights
Apparantly the red, blue, yellow dash mounted indicator lights get replaced as an entire unit. Anybody know how they come out of the dash??? Any tips??
The older I get, the faster I was.
Old 06-06-2016, 09:48 AM
Senile Club Cobra Member
They are individual and just push out from the rear.
rick@autoventureusa.net
Old 06-06-2016, 10:11 AM
The factory uses a thick silicone rubber to adhere them to the back of the dash panel. You will most likely need to use a utility knife and cut a slit on one side, then use some pliers to peel it away. They are in there pretty good but will easily back out once you do this.
Old 06-06-2016, 10:23 AM
Tim7139's Avatar
I could feel something but did'nt know what it was. Sounds pretty straight forward, thanks.
