  #21 (permalink)
Old 09-13-2018, 08:33 PM
zzmac's Avatar
Cobra Make, Engine: Superformance, Roush 402R
All retrieval attempts have been through the lower rad hose opening. :-)
I put a digital scope in there and i’ve been able to see it and it looks like it’s stuck in a corner. It’s one thing seeing it and another thing getting it out. I’m going to play around with it some more.
If I decide to take the rad out I understand it has to come out thru the bottom of the car. If so, how high does the car need to be. If higher than jack stands I’m going to have to get better with the scope.
  #22 (permalink)
Old 09-14-2018, 12:25 PM
zzmac's Avatar
Does anyone know if the rad can come out the bottom if I put the car up on jack stands? Would there be enough clearance?
  #23 (permalink)
Old 09-14-2018, 03:12 PM
Senile Club Cobra Member
Yes, if you pull the flat steel bar under the rad. I have dropped them out that way. You may need to bend or remove some of the plastic ducting but that is easy to reinstall.
rick@autoventureusa.net
  #24 (permalink)
Old 09-14-2018, 03:40 PM
zzmac's Avatar
Thanks everyone.
Rate This Thread:
