03-12-2019, 08:07 AM
Cobra Make, Engine: Superformance #2144 with a Roush 342R (sold June 2018, but still lurking on Club Cobra)
Hi Warren,
I replaced the leaking clutch reservoir on my Superformance (#2144) with a billet model several years ago. The worst part of the whole ordeal was removing the nuts on the inside of the firewall----having someone helping you is not a bad idea. Once they were removed and the bolts out, it was pretty straightforward process. Mind you, as noted by Tortuga, you do have to fabricate a bracket to hold the reservoir and avoid interference with the throttle rod. I used a piece of 1/8" aluminum (which I polished) for the bracket and bent and cut to fit. All told, it took about 4 hours from start to finish for the whole project.
