Old 06-25-2021, 04:37 AM
Default Looking for big brake kit
Looking for a big brake kit for my 15 inch wheels. Anyone found a good kit? Just want more breaking power. Everything on the car is original from superformance.
Old 06-25-2021, 05:52 AM
t walgamuth's Avatar
What size do you have presently?
Old 06-25-2021, 07:45 AM
LMH's Avatar
LMH LMH is offline
12.19” Wilwoods was about as big as I could fit under 15” alloys.
Alba gu brąth
Old 06-25-2021, 07:49 AM
You can achieve more clamping power without increasing rotor size by using larger diameter pucks on the brakes, or by decreasing the mc diameter.
The stronger clamping will be accompanied by needing more pedal pressure.
Are you after shorter stopping distance or less pedal pressure?
Old 06-25-2021, 09:33 AM
sunman's Avatar
Call Richard at North Racecars. Check website. Tell him what you got he will tell you what you need. 20 years designing and building brakes. Superformance, FFR he does them
Chaney Shores Studio
Old 06-25-2021, 04:17 PM
Senile Club Cobra Member
We have both four piston and six piston Wilwood kits for early SPFs, with solid rotors and slotted/drilled rotors as well. info@timemachinesauto.com What is the SPO # of your chassis?
rick@autoventureusa.net
Old 06-25-2021, 06:23 PM
cycleguy55's Avatar
Brakes that aren't properly broken-in and/or lightly used over a period of time tend to develop a glaze that significantly diminishes braking performance.
The first thing I do with marginal brakes is deglaze the rotors and pads and go through a rotor / pad break-in (burnish) procedure. That has solved the problem for me and those I've advised far more often than it hasn't.
If that doesn't do it, my next step would be a new set of pads with a compound matched to the type of driving I'll be doing.
I'd do all of the above before looking for different brakes.
Brian
Old 01-17-2022, 08:56 AM
Cobra Make, Engine: SPF 239
Not a kit, just a bunch of parts I put togeter years ago. (when I worked at Wilwood)
This was the biggest package that could fit inside the 15" SPF wheel
12.75x1.25 rotor with a narrow front superlite 6R caliper
I will warn you, If youre looking for better braking power, this alone will not get you there. The real issue is the pedal ratio/ master cylinder size/ booster.
Im on my third m/c - pedal itteration. currently working on a underfloor mounted, hydroboost actuated dual m/c rig with a balance bar
Old 01-17-2022, 11:58 AM
1985 CCX's Avatar
How about the Girling CR/ORA combo?
They can do that too at SPF, no?
